    M5StickC: turn off screen completely
    M5 Stick/StickC
    11
    25
    99.7k
    • D
      dda
      After a little bit of poking around I managed to turn off the screen:
      Wire1.beginTransmission(0x34);
      Wire1.write(0x12);
      Wire1.write(0b01001011);  // LDO2, aka OLED_VDD, off
      Wire1.endTransmission();
      This turns off LDO2, and thus the backlight. To turn it back on:
      Wire1.write(0x12);
      Wire1.write(0x4d); // Enable LDO2, aka OLED_VDD
      W 1 Reply Last reply Reply Quote 2
      • W
        ws1088 @dda
        @dda Thanks! @ricardocosta can probably check to see how much current is used when backlight is off.
        • D
          dda
          While I'm at it, an explanation about M5.Axp.ScreenBreath(x);. The code is:
          void AXP192::ScreenBreath(uint8_t brightness) {
            Wire1.write(0x28);
            Wire1.write(((brightness & 0x0f) << 4)); //Enable LDO2&LDO3, LED&TFT 3.3V
          What it does is it takes the value you passed, cuts it to 4 bits (0-15) and moves those 4 bits to bits 4-7. Register 28H is voltage control for LDO2 (bits 4-7) and LDO3 (bits 0-3). So the OLED is connected to LDO2.
          What that 0-15 value represents is a voltage of 1.8 to 3.3V, in 100mV/steps. So M5.Axp.ScreenBreath(0); sets voltage to 1.8V, and M5.Axp.ScreenBreath(15); to 3.3V. Not what we really want – as the goal was to set voltage to zero... :-)
          Whereas register 12H controls the state (ON/OFF) of a bunch of wires, including LDO2 (bit 2). Hence the code above.
          • W
            ws1088
            Does your code cut the voltage to the backlight only? or to the screen as well?
            • D
              dda
              To be tested but I think this turns off OLED_VDD, ie the current to the OLED. Register 10H is said to be for OLED_VPP so setting it to zero could help too.
              • D
                dda
                I did a simple test: with only REG 28H the screen stays slightly warm. With both 28H and 10H, the screen cools off after a while. Hardly a scientific test, I know, but seems to point to the need to set both registers.
                W K 2 Replies Last reply Reply Quote 0
                • W
                  ws1088 @dda
                  @dda what a wonderful work you have done! I hope this will enable @Multihelix to use M5StickC as a watch (turn off OLED after a timeout and turn on OLED on button press or accelerometer)
                    maxstack @Multihelix
                    @multihelix
                    How are you getting 5 hours of life? it seems you would need <16 ma total drain
                    Are you sleeping the ESP32?
                    • D
                      dda @ws1088
                      @ws1088 Funny enough I bought my M5StickC with the watch strap and all, but not because I wanted a watch – I don't wear them – but because it enables me to tie it up to my backpack when I do LoRa range tests :-)
                      • W
                        ws1088 @dda
                        @dda said in M5StickC: turn off screen completely:
                        why would you use m5stickc to do LoRa range tests? You can get LoRa chip with OLED screen. Do you connect m5stickc to a LoRa chip via I2C? or WiFi AP?
                        • D
                          dda
                          I have a lot of different LoRa chips and setups. I have one board, at 230 MHz, that I can connect through the hat connector (I need 3 pins + Vcc/GND). I have transceivers, both at 230 and 433 MHz, I connect to via RS485 (I bought a hat for that, and also some RS485 for my M5Stack cores). etc etc. The smaller the better :-)
                            Multihelix @maxstack
                            @maxstack - Yes, I used ESP DeepSleep set to wake on Button A being pressed, but I would say that the 5 hour time was not under ideal conditions, as I occasionally woke up the device to confirm it was still working and to check the time - a resonable activity for a watch.
                              spiffmonious @Multihelix
                              @multihelix Can you post a link to your watch code?
                              • K
                                klimbot @dda
                                I'm looking at this thread to hopefully implement a complete screen turn off, but am not sure what register mask to use (based on quoted post)
                                Here is what I have, the screen is off but hard to know if the screen has actually been disabled.
                                void turnOffScreen() {
                                Wire1.write(0x10);
                                Wire1.write(0b00000000); // 7-3=? | 2=EXTEN | 1=? | 0=DC-DC2
                                Wire1.begin(21, 22);
                                Wire1.write(0x12);
                                Wire1.write(0b01001011); // 7=? | 6=EXTEN | 5=? | 4=DC-DC2 | 3=LDO3 | 2=LDO2 | 1=DC-DC3 | 0=DC-DC1
                                Wire1.write(0x28);
                                Wire1.write(0b00001111); // 7-4=LDO2 | 3-0=LDO3
                                • F
                                  ForestRupicolous
                                  @klimbot: I think you have to turn LDO3 and LDO2 off, in your code only LDO2 is off. Take a look at this picture: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp
                                  • V
                                    viandou
                                    This is how I init my M5StickC in a full black screen way.
                                    M5.begin(0,1,1);
                                    M5.Axp.SetLDO2(false);
                                    M5.Axp.SetLDO3(false);
