    UI flow IMU issues
    12 Posts 4 Posters 22.6k Views 1 Watching
      hetzer
      Is there a custom block for calibration. I like to use uiflow and prefer not to go back to arduino.
      • m5-docsM Offline
        m5-docs @hetzer
        @hetzer Sorry about that I have asked engineer. He said that we'll not add this calibrated function block.
        M5Stack documentation URL
        https://docs.m5stack.com
          hetzer
          Is it possible to get to gyro code coming with the firmware. I can see the the dafult gyro app is working accurately but all my get x and get y block resulting random numbers
          • m5-docsM Offline
            m5-docs @hetzer
            @hetzer Are you sure that it is random data?
              hetzer
              Yes, en each start, while the unit is on the same position I get different values for x and y.
              Z starts from zero and just increases in each measurement.
              I tried to write a code to subtract the initial value from zero to calibrate but next x and y values within loop again starts from random values.
                hetzer
                Still no solution to this problem, the demo is working flawlessly but get_x, get?y and get_z provide wrong results. Can anyone help?
                • L Offline
                  liushasha @hetzer
                  @hetzer Hi, thanks for your feedback, the block naming on IMU is misleading. get-x get-y get-z actually is Yaw, Pitch, Roll.
                    hetzer @liushasha
                    @liushasha said in UI flow IMU issues:
                    I am aware but still the pitch and roll randomly varies around +-10 degrees and the roll value increase over time exceeding 360
                      hetzer
                      Managed to get some more accurate x and ydegrees.
                      Is it possible to get yaw heading with uiflow?
                        heybin
                        if only use mpu6050,i try fix yaw offset, but Failed .....
