    Disable start-up beep
    Cores
    6
    17
    35.3k
    • world101W
      world101 @m5er
      @m5er
      Yeah, I know about that for the Arduino IDE, but I was looking for a solution for uiFlow firmware.
      • H
        heybin @world101
        @world101 Hi,if you can flash firmware, i can provide a version without beep :)
        • world101W
          world101
          @heybin said in Disable start-up beep:
          I assume the first beep is compiled into the firmware bin file and not a configuration setting in one of the python files. Anyway, yes I can flash firmware, so please send it to me.
          • H
            heybin @world101
            Can you send your email to me by chats
            • world101W
              world101 @heybin
              @heybin
              I got it flashed and it's working good. No startup beep :-)
              For anyone else interested in v1.2.0 without the startup beeps...
              https://www.dropbox.com/s/093qcc7e51ywl4m/nobeep.zip?dl=0
              Pre-requisite: you must have esptool.py installed on your Mac and the m5stack is connected to a USB port.
              unzip nobeep.zip
              cd nobeep
              esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 erase_flash
              esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 write_flash -z 0x1000 ./bootloader.bin 0xf000 ./phy_init_data.bin 0x10000 ./MicroPython.bin 0x8000 ./partitions_mpy.bin
              esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 --before default_reset --after no_reset write_flash -z --flash_freq 40m 0x170000 ./spiffs_image_0x170000.img
              Reboot the m5stack.
              To silence the second beep (when choosing Upload, App.List, or Setup) do this:
              Pre-requisite: you must have ampy installed on your Mac
              ampy get /flash/boot.py
              Copy the entire output and create a new file called boot.py. Make the change below to set volume=0 in these three locations of the while loop.
              # wait 1000 for user choose
              cnt_down = time.ticks_ms() + 1000
              while time.ticks_ms() < cnt_down:
                  if buttonA.isPressed():   # M5Cloud upload
                      speaker.tone(2000, 50, volume=0, timer=False) # Beep
                      core_start('flow')
                      break
                  elif buttonB.isPressed(): # APP list
                      from app_manage import file_choose
                      file_choose()
                      core_start('app')
                      break
                  elif buttonC.isPressed(): # WiFi setting
                      import wifichoose
                      wifichoose.start()
                      break
              Upload the new file to the m5stack:
              ampy put boot.py /flash/boot.py
              Reboot the m5stack.
              • I
                iPodLux
                This is great!!! exactly what I was looking for.
                Would it be possible to have all new firmwares for both core/stick with and without beeps?!? It is quite annoying especially when prototyping with other people around, too many unnecessary resets and beeps
                Is there a way to put forward a formal request for no-beeps or options in main menu?
                • I
                  iPodLux
                  the ampy get /flash/boot.py command doesn't seem to work on my mac.
                  I've tried adding the uart address and bauds but no luck.....
                  any caveat?!
                  ajb2k3A world101W 2 Replies Last reply Reply Quote 0
                    ajb2k3 @iPodLux
                    @ipodlux There seams to be a few issues with mac at the moment, the crews are working on trying to solve them.
                    • world101W
                      world101 @iPodLux
                      @ipodlux said in Disable start-up beep:
                      any caveat?!
                      Did you install ampy on your Mac? If not, it won’t work. You can find install instructions here: https://learn.adafruit.com/micropython-basics-load-files-and-run-code/install-ampy
                      Also, I need to double check tomorrow, but starting with uiFlow firmware v1.2.3, I think the M5Stack team already disabled the first startup beep in the firmware.
                      • I
                        iPodLux @world101
                        @world101
                        Hi I certainly did it, ampy is installed and functional but doesn’t seem to connect to the device.
                        Thanks for looking into this. Removing all unnecessary beeps from the standard firmware would be great. No-one would buy a car honking at every steering or dashboard switch activation!
                        • world101W
                          world101 @iPodLux
                          @ipodlux
                          If it's not connecting to the device, what errors do you see? Paste your command line output here and maybe I can help further.
                          One other custom I did for ampy... I created the file ~/.ampy with these contents:
                          # Example .ampy file
                          # Please fill in your own port, baud rate, and delay
                          AMPY_PORT=/dev/tty.SLAB_USBtoUART
                          AMPY_BAUD=115200
                          # Fix for macOS users' "Could not enter raw repl"; try 2.0 and lower from there:
                          #AMPY_DELAY=0.5
                          If you create that file, you will not have to pass the port and baud rate options when running the ampy command. This is the standard way to run ampy when you don't have the .ampy file created.
                          world101$ ampy -p /dev/tty.SLAB_USBtoUART -b 115200 ls
                          /flash
                          Also, I was mistaken on the the v1.2.3 firmware with the beeps disabled by default. I just flashed one of my cores with the M5Burner and the beeps are there. I must have been running a custom firmware before.
