    M5stack basic core battery power on issue (ip5306 strange power management)
    Cores
    6
    28
    141.0k
    • L
      liushasha @arzaman
      @arzaman I apologize for the misleading on schematics, it is surely our mistake, we didn't well organize all of the material. We are working on it, will have better material come out soon.
      arzamanA 1 Reply Last reply Reply Quote 0
      • arzamanA
        arzaman @m5-docs
        @m5-docs I think we can conclude that is and "HW failure of IP5306" no big issue I can use this core for the lab or for application with no battery
        maybe if you can send me a replacement or tell me where to buy the I2C version of IP5306 I can try to replace by myself
        thanks for the support anyway
        • m5-docsM
          m5-docs @arzaman
          @arzaman The IP5306 which is iic version is customized. The best way for you is to ask saler for a replacement or ask our saler for a new core or iic version IP5306. Sorry for the inconvenience !
          M5Stack documentation URL
          https://docs.m5stack.com
          • arzamanA
            arzaman @liushasha
            @liushasha no problem...I had an old schema and did not check the note you add to the new one. Your documentation level is quite good and indeed If there is a problem I see there is quite good support on the forum and community ... in a way or another I get the info :-)
            most important that now I have more understanding of power management and the fact I can control battery via SW is very important (M5stack is perfect for portable applications battery pwered)
            could be VERY USEFUL a sort of translation of IP5306 Chinese data sheet
            there are few register that provide info but not able to unerstand the usage !!
            from various source I undertand that
            0x78 provides battery level (25/50/75/100)
            0x71 battery charging level (but not sure)
            what about the other registers ? what about control register ??
            simple table with register and functions/value will help a lot "non Chinese" speaking people
            hope to see soon in the documentation !
            thanks
            Davide
            m5-docsM arzamanA 2 Replies Last reply Reply Quote 0
            • m5-docsM
              m5-docs @arzaman
              @arzaman Thanks. Your seriousness really touched me.
              • arzamanA
                arzaman @arzaman
                I got also documentation for power management
                https://docs.m5stack.com/#/en/api/power?id=getbatterylevel
                clear and comprehnesive
                all ok issue "solved"
                Davide
                  ajb2k3 @arzaman
                  @arzaman said in M5stack basic core battery power on issue (ip5306 strange power management):
                  Davide
                  If you are getting an understanding of the power management of the IP5306, would you mind helping me write it up for my book please?
                  You will be credited for the information in the book.
                    As an addendum to this, the IP5306 is available from LCSC
                    https://lcsc.com/product-detail/PMIC-Battery-Management_IP5306_C181692.html
                    • C
                      ckuehnel
                      Here is a working code example:
                      • Test of IP5306 functions
                      #include <M5Stack.h>
                      void setup()
                      // initialize the M5Stack object
                      Wire.begin(); // required to access IP5306
                      M5.Lcd.fillScreen(BLACK);
                      M5.Lcd.setCursor(0, 10);
                      M5.Lcd.setTextColor(WHITE);
                      M5.Lcd.setTextSize(2);
                      M5.Lcd.printf("IP5306 Function Test\r\n");
                      if(!M5.Power.canControl())
                      M5.Lcd.setTextColor(RED);
                      M5.Lcd.printf("No communication with IP5306 chip");
                      while(1);
                      void loop()
                      M5.Lcd.fillRect(0,180,360,60,0);
                      uint8_t bat = M5.Power.getBatteryLevel();
                      M5.Lcd.setCursor(0,180);
                      if (M5.Power.isCharging()) M5.Lcd.printf("Battery is charging\r\n");
                      else M5.Lcd.printf("Battery is not charging\r\n");
                      M5.Lcd.printf("Battery Level %d", bat);
                      M5.Lcd.progressBar(0, 220, 360, 20, bat);
                      delay(5000);
                      ajb2k3A C 2 Replies Last reply Reply Quote 1
                        ajb2k3 @ckuehnel
                        @ckuehnel Thanks friend.
                        • C
                          cepics @ckuehnel
                          @ckuehnel said in M5stack basic core battery power on issue (ip5306 strange power management):
                          void setup()
                          while(1);
                          void loop()
                          delay(5000);
                          Hi, doesn't compile for me!!!
                          this is the arduino IDE output:
                          Arduino: 1.8.7 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                          Build options changed, rebuilding all
                          /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
                          /Users/AD/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
                             gpio_deep_sleep_hold_dis();
                          Multiple libraries were found for "SPI.h"
                           Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
                           Not used: /Users/AD/Documents/Arduino/libraries/SPI
                           Used: /Users/AD/Documents/Arduino/hardware/espressif/esp32/libraries/SD
                           Not used: /Users/AD/Documents/Arduino/libraries/SD
                           Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/395E70C5-F1F6-4076-AA11-9C132A2C6ACF/d/Arduino 1.8.7.app/Contents/Java/libraries/SD
                          exit status 1
                          tnks
