    [Solved]Lan Module and WiFi
    Modules
    5
    13
    19.7k
    • E
      elvis6m
      Hi!
      Could be possible to use the Lan module and the WiFi at the same time? I have noticed when I stack the Lan, to the M5 Basic, I start to lose the WiFi communication, maybe I need a cap somewhere...
      Best regards,
      Elvis
        salty_good @elvis6m
        @elvis6m Hi, I'm a SHIO.
        Our engineer said that you can use WiFI and LAN module at the same time.
        Please show us your code if you can.
        thank you.
        • T
          Thom
          Hello are there any solution ?
          or an example code ?
          Thanks for help
          Thomas
          • m5-docsM
            m5-docs
            @elvis6m I also need your code.
            M5Stack documentation URL
            https://docs.m5stack.com
            T 2 Replies Last reply Reply Quote 0
            • T
              Thom @m5-docs
              Thanks @elvis6m for your attention. Here is the siplified code,
              // Ethernet Settings * i try to use Example "M5Stack/Modules/W5500/Webserver"
              // Problem: M5Stack LAN Module works with this settings but only seperate code not together with WiFi at same time,
              // _________& OTA was as well not possible
              // _________https://m5stack.readthedocs.io/en/master/product-documents/modules/m5stack_lan_module.html
              // MyProject : connect to home WiFi accesspoint, if done, then Button A pass an UDP message to 2channel LAN relais
              //____________connected at the RJ45 M5Stack LAN Module.
              // (so fare works only via home wifi accesspint to lan, but not when we connect the crossovercable to M5StackLAN)
              #include <M5Stack.h>
              #include "WiFi.h"
              #include <WebServer.h>
              WebServer server(80);
              //for static IP address configuration
              IPAddress staticIP(192, 168, 178, 39); //M5stack static ip
              IPAddress gateway(192, 168, 178, 100); //IP Address of your WiFi Router (Gateway)
              IPAddress subnet(255, 255, 255, 0); //Subnet mask
              IPAddress dns(192, 168, 178, 100); //DNS
              #include <AsyncUDP.h>
              #include <WiFiUdp.h>
              #include <ArduinoOTA.h>
              //UDP
              WiFiUDP Udp, Udp2 ;
              char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
              #define TFT_GREY 0x5AEB
              //SSID and Password of your WiFi router
              const char* WiFi_hostname = "M5Stack"; // works with M5Stack, NudeMCU , D1 Mini(Board 12E Module).
              const char* ssid = "test"; //"SSID"type your ssid,
              const char* password = "test"; //type your password,
              M5.Lcd.clear();
              M5.Lcd.println("m5.begin");
              WiFi.setHostname(WiFi_hostname); //Name im WiFi router
              //WiFi.config(staticIP, subnet, gateway, dns);
              WiFi.begin(ssid, password); //Connect to your WiFi router
              WiFi.mode(WIFI_STA);
              Serial.println("");
              Serial.println("wiwfi");
              Serial.println("");
              M5.Lcd.println("..");
              // wait for connection
              delay(500);
              Serial.print(F("."));
              M5.Lcd.print(F("."));
              //OTA
              // Port defaults to 8266
              ArduinoOTA.setPort(8266);
              // Hostname defaults to esp8266-[ChipID]
              ArduinoOTA.setHostname(WiFi_hostname);
              ArduinoOTA.onStart( {
              M5.Lcd.clear();
              M5.Lcd.println("..start update prozess" );
              //  display.display();
              String type;
              if (ArduinoOTA.getCommand() == U_FLASH) {
                type = "sketch";
              } else { // U_SPIFFS
                type = "filesystem";
              Serial.println("Start updating " + type);
              ArduinoOTA.onEnd( {
              Serial.println("\nEnd");
              ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
              Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
              M5.Lcd.setTextSize(3);
              M5.Lcd.setCursor(20, 60);
              M5.Lcd.print("..update" );
              M5.Lcd.print( String((progress / (total / 100))) + " % " );
              ArduinoOTA.onError([](ota_error_t error) {
              Serial.printf("Error[ % u]: ", error);
              if (error == OTA_AUTH_ERROR) {
              Serial.println("Auth Failed");
              } else if (error == OTA_BEGIN_ERROR) {
              Serial.println("Begin Failed");
              } else if (error == OTA_CONNECT_ERROR) {
              Serial.println("Connect Failed");
              } else if (error == OTA_RECEIVE_ERROR) {
              Serial.println("Receive Failed");
              } else if (error == OTA_END_ERROR) {
              Serial.println("End Failed");
              ArduinoOTA.begin();
              Serial.println("Ready");
              M5.Lcd.setTextSize(1); //zurücksetzen
              //OTA ENDE
              startWebServer(); // starting webserver
              M5.Lcd.setCursor(0, 0);
              M5.Lcd.setTextSize(2);
              M5.Lcd.println(String(WiFi_hostname));
              M5.Lcd.println(WiFi.localIP());
              } // ENDE SETUP
              //xxxxxxxxxxxxxxxxxxxxxxxxxxx LOOP xxxxxxxxxxxxxxxxxxxxxxxxxxx
              ArduinoOTA.handle();
              delay(80);
              server.handleClient(); //Handle client requests
              M5.update();
              if (M5.BtnA.wasReleased()) {
              M5.Lcd.print('A');
              RelaissendUDP();
              } else if (M5.BtnB.wasReleased()) {
              M5.Lcd.print('B');
              } else if (M5.BtnC.wasReleased()) {
              M5.Lcd.print('C');
              } // END of LOOP
              void startWebServer()
              // Root-URL
              server.on("/", handleRoot);
              // further path
              server.on("/m5", {
              server.send(200, "text/plain", "m5 path hello");
              // relaistrigger
              server.on("/11", RelaissendUDP);
              // and further more if need.
              // if path not valid
              server.onNotFound(handleNotFound);
              // server ok so, go
              server.begin();
              Serial.println("HTTP server started");
              void handleNotFound()
              String message = "File Not Found\n\n";
              message += "URI: ";
              message += server.uri();
              message += "\nMethod: ";
              message += (server.method() == HTTP_GET) ? "GET" : "POST";
              message += "\nArguments: ";
              message += server.args();
              message += "\n";
              for (uint8_t i = 0; i < server.args(); i++) {
              message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
              server.send(404, "text/plain", message);
              void handleRoot()
              String content = String(WiFi_hostname)+"<br> this button trigger the relais same way button A at M5stack <a href="/11">RELAISTRIGGER</a></body></html>";
              String s = "<!DOCTYPE html><html><head>";
              s += "<meta name="viewport" content="width=device-width,user-scalable=0">";
              s += "<title>";
              s += "M5Stack";
              s += "</title></head><body>";
              s += content;
              s += "</body></html>";
              server.send(200, "text/html", "OK http connect: " + s);
              //LAN 2Chanal Relais
              void RelaissendUDP ()
              // 2WayRelais
              IPAddress 2channelRelais(192, 168, 178, 32);
              unsigned int UDP2port = 6723; //sendePport 6723 UDP für 2WayRelais, TCP port 6722
              const int UDP_PACKET_SIZE = 4; //packetgroesse wictig rüf Relaisansteuerung
              byte packet2Buffer[ UDP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
              boolean packet2Rcvd = true;
              delay(10);
              memset(packet2Buffer, 0, UDP_PACKET_SIZE);
              sprintf((char*)packet2Buffer, "11:5"); //PCB Relais2, close for 5seconds
              Udp.beginPacket(2channelRelais, UDP2port);
              Udp.write(packet2Buffer, UDP_PACKET_SIZE);
              Udp.endPacket();
              delay(10);
              sprintf((char*)packet2Buffer, "12:4"); //PCB Relais2, close for 4seconds
              Udp.endPacket();
              • T
                Thom @Thom
                @thom said in Lan Module and WiFi:
                " char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,"
                this row can be deleted.
                • T
                  Thom @m5-docs
                  @m5-docs
                  Hello @elvis6m let me ask for an uptate , thank you, best regards Thomas
                  • T
                    Thom
                    Hello There, are the an way to get it solved ? :-/
                    so far i couldn't find it.
                    Greeets Thomas
                    http://forum.m5stack.com/topic/763/solved-lan-module-and-wifi
                    • T
                      Thom @salty_good
                      @salty_good Hello, are there any solution meawhile?
                        Hello Thomas
                        If I read your code correctly the UDP packets are sent out via WiFi instead of the Ethernet interface. I think you'll need to include Ethernet2 library (from M5 Stack W5500 WebServer example) and then include and declare the following:
                        #include <Ethernet2.h>
                        #include <EthernetUdp2.h>
                        EthernetUDP Udp;
                        instead of
                        WiFiUDP Udp, Udp2 ;
                        The Ethernet interface needs to be initialised as well with something like this (taken from M5Stack W5500 WebServer example):
                        #define SCK 18
                        #define MISO 19
                        #define MOSI 23
                        #define CS 26
                        // Enter a MAC address and IP address for your controller below.
                        // The IP address will be dependent on your local network:
                        byte mac[] = {
                          0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
                        IPAddress ip(192, 168, 1, 177);
                          SPI.begin(SCK, MISO, MOSI, -1);
                          Ethernet.init(CS);
                          // start the Ethernet connection and the server:
                          Ethernet.begin(mac, ip);
                        Note: all of the above is untested and might need some additional fine tuning.
                        Good luck!
                        Cheers
                        • T
                          Thom
                          Thanks Felix,
                          meanwhile i got it work with via ethernet.h , same wway like your post.
                          But the main skill was and still is unsolved, how get it work with LAN and WIFI together.
                          OR anway switch within one code between wifi and lan.
                          so fare i dint found an way to update the sketch .bin via LAN.
                          Almost all very nice codes working perfekly via WIFI webserver upload .
                          like :
                          "HTTPUpload& upload = server.upload();"
                          or
                          " t_httpUpdate_return ret = ESPhttpUpdate.update(update_server, 80, update_uri, firmware_version);"
                          but via ethernet, i am not able to get it wokrk i found nothing so fare :-/
                          greeets Thomas
                            Hello Thomas
                            glad to hear you've got Ethernet working.
                            From what I can tell the HTTPUpdate library only supports OTA over WiFi connections. So in order to use Ethernet for OTA I guess you'd need to modify the HTTPUpdate library to use an Ethernet connection instead of WiFi.
                            Greetings
                              Hello again
                              I think the following library should allow you to switch between WiFi or Ethernet OTA:
                              https://github.com/espressif/arduino-esp32/tree/master/libraries/Update
                              Use it with either a WiFiClient or EthernetClient client.
                              Cheers
