    Interrupts?
    UIFlow
    9.5k
    • L
      LastCaress
      So is there any way to use external interrupts in flow.m5stack.com ? (using the micropython code)? I tried using the methods for micropython but irq is not an attribute for pin objects.
      Thanks!
      • L
        LastCaress @LastCaress
        @lastcaress I used the code for the button pressed, but don't know if this is accurate?
          I don't understand interrupts myself but I believe that if you use the button loop instead of the system loop that that is an interrupt.
          Please bare with me as I'm still documenting and exploring UIFlow.
          • H
            heybin
            flow.m5stack.com, buttonA, B, C has been implemented using interrupts, or try:
            from m5stack import m5button
            button = m5button.register(_BUTTON_PIN)
