    Neopixel units not working in uiflow 1.2
    Bug Report
    15
    21.4k
      Conformed, no response to Neopixels on M5Core
      • m5-docsM
        m5-docs
        Recommend to use FastLED library instead of neopixel library
        M5Stack documentation URL
        https://docs.m5stack.com
          ajb2k3 @m5-docs
          @watson said in Neopixel units not working in uiflow 1.2:
          how do you use fast led in UIFLOW
          • lukasmaximusL
            Noted, thanks for the heads up guys, and my apologies. I will inform the team and we'll get it sorted asap. @watson they are talking about no neopixel control in uiflow not in arduino
              Neopixel hex not working with M5Stick on Firmware 1.2.2 in UIFLOW!
              • m5-docsM
                m5-docs @ajb2k3
                Hello @ajb2k3 Do you mean this unit?
                  ajb2k3 @m5-docs
                  @watson
                  Yes the Hex, was working fine before the 1.2 update.
                  • m5-docsM
                    m5-docs @ajb2k3
                    @ajb2k3 Have you connected HEX with the input direction?
                      As I said before, it was all working pre 1.2 via port A the i2c port.
                      • m5-docsM
                        m5-docs @ajb2k3
                        @ajb2k3 As a software engineer told, version 1.2.2 has fixed this bug. You can try it.
                          ajb2k3 @m5-docs
                          Works with M5STACK
                          Does not work with M5STICK!
                          • m5-docsM
                            m5-docs @ajb2k3
                            @ajb2k3 Does you keep M5Stick be lastest vesrion (v1.2.2) ?
                              ajb2k3 @m5-docs
                              @watson Yes,
