    M5StackSAM - Application Menu Library
    PROJECTS
    7
    14
    39.2k
    • T
      TomSuch
      For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
      https://github.com/tomsuch/M5StackSAM
      JJJ 1 Reply Last reply Reply Quote 4
      • K
        kaotiklabs
        @TomSuch Thanks! I think this will be really helpful.
        Don't need to waste time setting a my quick dirty menu anymore :)
        • JJJ
          JJ @TomSuch
          @tomsuch
          Nice one Tom. Thanks. Should be handy for many users....
          • reaper7R
            reaper7
            simple app Accu meter (MAX17043 module soldered inside Battery Module):
            code based on nlamprian library from https://github.com/nlamprian/LiFuelGauge:
            available on my gist:
            https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4
            • 面
              面包
              不知楼主是否看得懂中文~哈哈
              这个例子非常好,已经借用,谢谢作者TomSuch~
              另外,建议做菜单列表,比现在的菜单页面直观一些。
              APPLICATION
              1.APP1
              2.APP2
              3.RETRUN
              SYSTEM
              1.SYSTEM INFO
              2.SLEEP/..
              3.RETRUN
              • J
                jwdberlin @reaper7
                @reaper7 shows strange values: VCell: -0.0213V SoC: -1.00%
                what's going wrong?
                • JJJ
                  JJ
                  @jwdberlin
                  Hi, just checking... have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example ?
                  • reaper7R
                    reaper7
                    @jwdberlin - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?
                    Try first with regular library:
                    https://github.com/nlamprian/LiFuelGauge/
                    @JimiT - good question :)
                    • JJJ
                      JJ @reaper7
                      @reaper7
                      Hi Reaper7, I'm planning to do this mod.
                      Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.
                      So you've removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....
                      Is that right? And the rest ? Thanks !
                      • reaper7R
                        reaper7
                        cutting pcb is not necessary,
                        cutting wire between ACCU+ and VCC also not necessary
                        but I do not want drain accu by max17043 when m5stack is off
                        REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,
                        then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V
                        JJJ 1 Reply Last reply Reply Quote 2
                        • JJJ
                          JJ @reaper7
                          @reaper7
                          Excellent thanks very much !
                          • J
                            jwdberlin @JJ
                            @jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...
                            • D
                              DoNcK
                              A bit off-topic:
                              Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)
                              (FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP not sleeping)
                              • T
                                TomSuch
                                A new version of the M5StackSAM library
                                Added features to easily create and navigate the list.
                                (APPLICATIONS -> LIST DEMO)
                                Added support for the FACES QWERTY keyboard.
                                (APPLICATIONS -> FACES GET STRING)
