    Optimized Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850) available on HF
    SOFTWARE
    • G
      gregm123456
      I have optimized the Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850):
      https://huggingface.co/gregm123456/realistic-vision-v6-axera-hw
      Realistic Vision is optimized for more general photorealism, and this optimized vesion can be used in place of the model that was chosen for this example:
      https://github.com/AXERA-TECH/sd1.5-lcm.axera
        seahope @gregm123456
        @gregm123456 HI. I don't suppose you know how to ask the driver developers about bugs? I am getting a lot of this:
        67% | ██████████████████████ | 21 / 31 [20.57s<30.37s, 1.02 count/s] init 11 axmodel ok,devid(0) remain_cmm(3954 MB)[2026-01-25 14:53:12.889][3991][E][engine][invoke][97]: Decode api(4) response failed.
        [E][ init][ 421]: AX_ENGINE_CreateHandle
        70% | ███████████████████████ | 22 / 31 [21.09s<29.71s, 1.04 count/s] init 4 axmodel ok,devid(0) remain_cmm(4014 MB)[2026-01-25 14:53:14.038][3991][E][engine][invoke][97]: Decode api(4) response failed.
        74% | ████████████████████████ | 23 / 31 [22.57s<30.42s, 1.02 count/s] init 19 axmodel ok,devid(0) remain_cmm(3825 MB)[2026-01-25 14:53:14.843][3991][E][engine][invoke][97]: Decode api(4) response failed.
        77% | █████████████████████████ | 24 / 31 [23.04s<29.76s, 1.04 count/s] init 26 axmodel ok,devid(0) remain_cmm(3885 MB)[2026-01-25 14:53:15.992][3991][E][engine][invoke][97]: Decode api(4) response failed.
        80% | ██████████████████████████ | 25 / 31 [24.57s<30.47s, 1.02 count/s] init 12 axmodel ok,devid(0) remain_cmm(3696 MB)[2026-01-25 14:53:16.796][3991][E][engine][invoke][97]: Decode api(4) response failed.
        83% | ███████████████████████████ | 26 / 31 [25.00s<29.80s, 1.04 count/s] init 5 axmodel ok,devid(0) remain_cmm(3756 MB)[2026-01-25 14:53:17.945][3991][E][engine][invoke][97]: Decode api(4) response failed.
        87% | ████████████████████████████ | 27 / 31 [26.57s<30.51s, 1.02 count/s] init 20 axmodel ok,devid(0) remain_cmm(3567 MB)[2026-01-25 14:53:18.751][3991][E][engine][invoke][97]: Decode api(4) response failed.
        90% | █████████████████████████████ | 28 / 31 [26.95s<29.84s, 1.04 count/s] init 27 axmodel ok,devid(0) remain_cmm(3627 MB)[E][ init][ 421]: AX_ENGINE_CreateHandle
        [2026-01-25 14:53:19.897][3991][E][engine][invoke][97]: Decode api(4) response failed.
        [2026-01-25 14:53:20.654][3991][E][engine][invoke][97]: Decode api(4) response failed.
        93% | ██████████████████████████████ | 29 / 31 [28.53s<30.49s, 1.02 count/s] init 6 axmodel ok,devid(0) rema 96% | ███████████████████████████████ | 30 / 31 [28.54s<29.49s, 1.05 count/s] init 13 axmodel ok,devid(0) rem100% | ████████████████████████████████ | 31 / 31 [34.14s<34.14s, 0.91 count/s] init post axmodel ok,remain_cmm(3302 MB)Working directory: /home/stevef/dev/Qwen3-1.7B
        Starting tokenizer server on port 12300...
        Server running on port 12300
        Starting main API application...
        [I][ Init][ 130]: LLM init start
        [I][ Init][ 34]: connect http://127.0.0.1:12300 ok
        [I][ Init][ 57]: uid: cacc4142-cf79-4f83-b257-4a4cd94707bb
        bos_id: 151643, eos_id: 151645
        3% | ██ | 1 / 31 [0.88s<27.19s, 1.14 count/s] tokenizer init ok[I][ Init][ 45]: LLaMaEmbedSelector use mmap
        6% | ███ | 2 / 31 [0.88s<13.59s, 2.28 count/s] embed_selector init ok
        [I][ run][ 30]: AXCLWorker start with devid 0
        [2026-01-25 14:53:47.641][4245][E][engine][invoke][97]: Decode api(4) response failed.
        [2026-01-25 14:53:48.398][4245][E][engine][invoke][97]: Decode api(4) response failed.
        9% | ████ | 3 / 31 [3.57s<36.87s, 0.84 count/s] init 0 axmodel ok,devid(0) remai 12% | █████ | 4 / 31 [3.87s<29.96s, 1.03 count/s] init 7 axmodel ok,devid(0) remain_cmm(5117 MB)[2026-01-25 14:53:49.159][4245][E][engine][invoke][97]: Decode api(4) response failed.
        16% | ██████ | 5 / 31 [4.87s<30.19s, 1.03 count/s] init 21 axmodel ok,devid(0) remain_cmm(5117 MB)[2026-01-25 14:53:49.963][4245][E][engine][invoke][97]: Decode api(4) response failed.
        19% | ███████ | 6 / 31 [5.46s<28.20s, 1.10 count/s] init 14 axmodel ok,devid(0) remain_cmm(4983 MB)[2026-01-25 14:53:51.308][4245][E][engine][invoke][97]: Decode api(4) response failed.
        22% | ████████ | 7 / 31 [6.87s<30.43s, 1.02 count/s] init 1 axmodel ok,devid(0) remain_cmm(4859 MB)[2026-01-25 14:53:52.113][4245][E][engine][invoke][97]: Decode api(4) response failed.
        25% | █████████ | 8 / 31 [7.87s<30.50s, 1.02 count/s] init 8 axmodel ok,devid(0) remain_cmm(4859 MB)[E][ init][ 421]: AX_ENGINE_CreateHandle
        [2026-01-25 14:53:52.917][4245][E][engine][invoke][97]: Decode api(4) response failed.
        [2026-01-25 14:53:53.870][4245][E][engine][invoke][97]: Decode api(4) response failed.
        29% | ██████████ | 9 / 31 [9.04s<31.14s, 1.00 count/s] init 15 axmodel ok,devid(0) rema 32% | ███████████ | 10 / 31 [9.06s<28.08s, 1.10 count/s] init 22 axmodel ok,devid(0) remain_cmm(4789 MB)[E][ init][ 421]: AX_ENGINE_CreateHandle
        [2026-01-25 14:53:55.025][4245][E][engine][invoke][97]: Decode api(4) response failed.
        35% | ████████████ | 11 / 31 [10.87s<30.64s, 1.01 count/s] init 2 axmodel ok,devid(0) remain_cmm(4600 MB)[2026-01-25 14:53:55.829][4245][E][engine][invoke][97]: Decode api(4) response failed.
        38% | █████████████ | 12 / 31 [11.32s<29.25s, 1.06 count/s] init 9 axmodel ok,devid(0) remain_cmm(4660 MB)[2026-01-25 14:53:56.977][4245][E][engine][invoke][97]: Decode api(4) response failed.
        Infinite loop only solved by a reboot
        wayner.dW 1 Reply Last reply Reply Quote 0
        • wayner.dW
          wayner.d @seahope
          @seahope Interesting post! Leveraging HF models like Realistic Vision with the AX8850 module sounds like a solid step toward faster, more efficient on-device AI workflows.
