    Tab5 USBHIDKeyboard
    General
    1.2k
    • J
      jalmalogni
      I am attempting to use Tab5 to send keyboard events through a usb connection. I am able to use similar code to send keystrokes when using a Cardputer. I took the touch button example and added keyboard print(string) and write(keycode) to the button event. I also tried adding a delay after calling keyboard.begin()
      Using the same cable connection, the Cardputer successfully sends keyboard events to the computer, but the computer does not seem to receive any events from the Tab5.
      Is any way I can try to debug this?
      #include <M5Unified.h>
      #include <M5GFX.h>
      #include "USB.h"
      #include "USBHIDKeyboard.h"
      m5::touch_detail_t touchDetail;
      static int32_t w;
      static int32_t h;
      LGFX_Button button;
      USBHIDKeyboard Keyboard;
        w = M5.Lcd.width();
        h = M5.Lcd.height();
        M5.Lcd.fillScreen(WHITE);
        M5.Display.setRotation(0);
        M5.Display.setTextDatum(top_center);
        M5.Display.drawString("Button Released", w / 2, 0, &fonts::FreeMonoBold24pt7b);
        button.initButton(&M5.Lcd, w / 2, h / 2, 200, 200, TFT_BLUE, TFT_YELLOW, TFT_BLACK, "BTN", 4, 4);
        button.drawButton();
        Keyboard.begin();
        USB.begin();
        delay(4000);
        M5.Display.drawString("usb done", w / 2, 100, &fonts::FreeMonoBold24pt7b);
        M5.update();
        touchDetail = M5.Touch.getDetail();
        if (touchDetail.isPressed()) {
          if(button.contains(touchDetail.x, touchDetail.y)){
              M5.Display.drawString("Button  Pressed", w / 2, 0, &fonts::FreeMonoBold24pt7b);
              Keyboard.print("hello");
              Keyboard.write(KEY_RETURN);
              delay(2000);
        else {
      • Y
        yuyun2000 @jalmalogni
        @jalmalogni To debug the USB keyboard issue with your Tab5 (SKU:C145/K145), please try the following steps:
        Verify USB OTG Configuration: Ensure your code correctly initializes USB OTG mode. Add these build flags to your PlatformIO configuration:
        build_flags =
        -DARDUINO_USB_CDC_ON_BOOT=1
        -DARDUINO_USB_MODE=1
        Check USB Initialization Order: Modify the initialization sequence in setup():
        USB.begin(); // Initialize USB first
        delay(1000); // Add delay before keyboard initialization
        Keyboard.begin();
        Monitor USB Enumeration: Connect via WebTerminal through UiFlow2 to check if the USB device is recognized. Navigate to the serial monitor and look for USB HID initialization messages.
        Test Hardware Connection: Ensure you're using the USB-C port (labeled as USB 2.0 OTG) on Tab5, not the USB-A host port. Try different USB cables known to work with data transfer.
        Simplify Test Code: Use this minimal example to isolate the issue:
        #include "USB.h"
        USB.begin();
        delay(2000);
        Keyboard.begin();
        M5.Lcd.print("USB HID Ready");
        M5.update();
        if (M5.BtnA.wasPressed()) {
        Keyboard.print("Hello");
        Check Power Management: Ensure Tab5 is sufficiently powered (use external power if battery level is low). USB HID functionality may be disabled under low power conditions.
        https://chat.m5stack.com/
        • J
          jalmalogni
          Thank you for your time and help yuyun2000!
          I am using ArduinoIDE. I have attempted to setup PlatformIO, but I was not able to find any information on setting up PlatformIO for the Tab5. I also tried UIFlow2, but when I tried to use M5Burner to load the firmware on the Tab5, it would just display a window with no firmware options.
          I tried the simplified code. I do not know how to trigger BtnA.wasPressed, so I copied the Keyboard.print and Keyboard.write to the end of the setup function.
          This code does work OK for the Cardputer, but there is no keyboard output when using the same simplified code with the same usb cable on the Tab5.
          I have tested this on the Tab5 with the battery attached, but there is still no keyboard output.
          I have only been able to get ArduinoIDE working so far, and I have attempted setting up ArduinoIDE on a new Fedora installation with the same results.
          Has anyone been successful in getting OTG HID keyboard output from the Tab5?
          • L
            LETSOC @jalmalogni
            @jalmalogni I am looking at exploring something similar and didn’t manage also. I looked at the MAX3421e usb module v1.2 I was hoping that would make it happen but seems like the communication doesn’t happen. Power comes out and powers the usb peripherals but no communication data.
            Annoying as on paper this should be possible I am wondering if you had any success with your project and can share any details.
            reddit
