Visual Code and M5StamPLC with new M5Unified
I use M5StamPLC under Visual Code with this platform.ini: Topic 7784.
Since 10 hours ago there is the new version 0.2.8 of M5Unified. With a short test program I got this errors:
Compiling .pio/build/xxx/libad7/M5Unified/utility/power/INA226_Class.cpp.o Archiving .pio/build/xxx/lib056/libM5GFX.a Compiling .pio/build/xxx/libad7/M5Unified/utility/power/INA3221_Class.cpp.o .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:78:12: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} { board_t::board_M5CardputerADV,GPIO_NUM_9 ,GPIO_NUM_8 , GPIO_NUM_1 ,GPIO_NUM_2 }, ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:82:12: error: 'board_M5AtomEchoS3R' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} { board_t::board_M5AtomEchoS3R, GPIO_NUM_0 ,GPIO_NUM_45 , GPIO_NUM_1 ,GPIO_NUM_2 }, ^~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:151:12: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} { board_t::board_M5CardputerADV,GPIO_NUM_40, GPIO_NUM_14, GPIO_NUM_39, GPIO_NUM_12 }, ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:178:12: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} { board_t::board_M5CardputerADV,GPIO_NUM_21 }, ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp: In member function 'm5::board_t m5::M5Unified::_check_boardtype(m5::board_t)': .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1151:30: error: 'board_M5AtomEchoS3R' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} board = board_t::board_M5AtomEchoS3R; ^~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp: In member function 'void m5::M5Unified::_begin(const m5::M5Unified::config_t&)': .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1462:19: error: 'board_M5AtomEchoS3R' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5AtomEchoS3R: ^~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1478:19: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5CardputerADV: ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp: In member function 'void m5::M5Unified::_begin_spk(m5::M5Unified::config_t&)': .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1587:21: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5CardputerADV: ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1768:21: error: 'board_M5AtomEchoS3R' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5AtomEchoS3R: ^~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1839:21: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5CardputerADV: ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:1847:34: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} if (_board == board_t::board_M5CardputerADV) { ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp: In member function 'virtual void m5::M5Unified::update()': .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:2232:19: error: 'board_M5CardputerADV' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5CardputerADV: ^~~~~~~~~~~~~~~~~~~~ .pio/libdeps/xxx/M5Unified/src/M5Unified.cpp:2241:19: error: 'board_M5AtomEchoS3R' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'} case board_t::board_M5AtomEchoS3R: ^~~~~~~~~~~~~~~~~~~ Compiling .pio/build/xxx/libad7/M5Unified/utility/power/IP5306_Class.cpp.o Compiling .pio/build/xxx/libfc2/FS/FS.cpp.o *** [.pio/build/xxx/libad7/M5Unified/M5Unified.cpp.o] Error 1I try to use the version 0.2.7 in platform.ini:
lib_deps = M5StamPLC=https://github.com/m5stack/M5StamPLC M5Unified=https://github.com/m5stack/M5Unified^0.2.7It didn't work. The version 0.2.7 and 0.2.8 was used and I got the same errors.
Who can help?
I've gotten a little closer to the problem. First, I performed a full clean in Visual Studio using platformio AND deactivated the entry for M5Unified. The new M5Unified@0.2.8 continued to load:
Processing m5stampplc-test (platform: espressif32; board: esp32-s3-devkitc-1; framework: arduino) ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Library Manager: Installing git+https://github.com/m5stack/M5StamPLC git version 2.43.0 Cloning into '/Users/myname/.platformio/.cache/tmp/pkg-installing-pmi7_zhl'... remote: Enumerating objects: 70, done. remote: Counting objects: 100% (70/70), done. remote: Compressing objects: 100% (57/57), done. remote: Total 70 (delta 4), reused 29 (delta 1), pack-reused 0 (from 0) Receiving objects: 100% (70/70), 80.39 KiB | 2.77 MiB/s, done. Resolving deltas: 100% (4/4), done. Library Manager: M5StamPLC@1.0.0+sha.1021da5 has been installed! Library Manager: Resolving dependencies... Library Manager: Installing M5Unified @ * Unpacking [####################################] 100% Library Manager: M5Unified@0.2.8 has been installed! Library Manager: Resolving dependencies... Library Manager: Installing M5GFX @ >=0.2.10 Unpacking [####################################] 100% Library Manager: M5GFX@0.2.10 has been installed!A look at the library.json revealed the challenge in my opinion: dependencies to "M5Unified" - No specific version of M5Unified, always the latest!
"name": "M5StamPLC", "description": "Library for M5StamPLC", "keywords": "M5Stack,M5StamPLC", "authors": { "name": "M5Stack" }, "repository": { "type": "git", "url": "https://github.com/M5Stack/M5StamPLC.git" }, "dependencies": { "M5Unified": "*", "M5GFX": "*" }, "version": "1.0.0", "frameworks": "arduino", "platforms": "espressif32" }Before I copy and adapt everything locally, it would certainly be helpful to adapt this. In my opinion, there must be an M5StamPLC version 1.0.1 with the new features, and the old version M5StamPLC 1.0.0 must use M5Unified version 0.2.7. Who (from M5Stack) can help me?
