    How to solve the UI memory leak?
    UiFlow 2.0
    • Z
      zhumingqi
      I used UIFlow2.3.3 to develop a simple UI demo. There is only one image widget to switch 2 JPG images every second. When I monitor the memory with gc.mem_free, I found the memory reduced continiously. And finally, the image switching was stop, but the loop was running. I wonder how to solve the UI memory leak? Here is my python code:
      import os, sys, io
      import M5
      from M5 import *
      import time
      image0 = None
      oldData14 = None
      ImgFlag = None
      def setup():
      global image0, oldData14, ImgFlag
      M5.begin()
      Widgets.fillScreen(0x000000)
      image0 = Widgets.Image("/flash/res/img/default.jpg", 0, 0, scale_x=1, scale_y=1)
      image0.setImage("/flash/res/img/RotaryBGBacklight.jpg")
      ImgFlag = 0
      def loop():
      M5.update()
      if (time.localtime())[5] != oldData14:
      PrintFreeMem()
      oldData14 = (time.localtime())[5]
      if ImgFlag == 0:
      image0.setImage("/flash/res/img/RotaryBGBT.jpg")
      ImgFlag = 1
      elif ImgFlag == 1:
      ImgFlag = 0
      else:
      pass
      def PrintFreeMem():
      print("Free mem:", gc.mem_free())
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
      And my UIFlow2 design:
      Z 1 Reply Last reply Reply Quote 0
      • Z
        zhumingqi @zhumingqi
        I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
