    Tab5 Screen Protector
    General
    • K
      Kenzo
      Not exactly sure where to post this BUT over the weekend I created a simple screen protector sheet design for the M5stack Tab5.
      I laser cut the design out onto a sheet of screen protector.
      I have exported the design out into multiple file types ( .svg, .dxf, .ai, .lbrn2) so hopefully one of four file types will work for people who may be interested in making a screen protector for their Tab5.
      Just be sure to be careful and take the necessary precautions when dealing with the fumes when cutting material with a Laser Cutter...
      Github Link to design files: https://github.com/KenzoWright/M5Stack_Tab5_Accessories
      Screen Protector sheets I used: https://amzn.to/4flH2PM
      Also if anyone knows of a I2C Micro Tube Air sensor that has successfully worked with the Tab5 please send me a message. I am searching for a Tube Air sensor that can detect if someone blows over a tube or lightly into it.
      I have tried using M5Stack's Tube Air Sensor ( SKU: U130 ) but I am having issues getting it to work with the Tab5 and I don't know if that sensor will be sensitive and accurate enough to detect someone lightly blowing into the tube. So the sensor will have to be sensitive and accurate as well as compatible with the M5Stack’s I2C implementation with the 5 volt power supply…
      Thanks and I hope the community finds the screen protector useful!
