    Error!!!!????
    General
    256
    • N
      Nooblearns @ajb2k3
      @ajb2k3 I was trying to burn UI flow to the M5 stick. What I'm reading is I need CH340 or CP210x? My brother a Dev, is gonna stop by tomorrow and try and help.
      I appreciate the reply.
      • N
        Nooblearns @ajb2k3
        @ajb2k3 ERROR: Command not found at ''
          ajb2k3 @Nooblearns
          @Nooblearns have you installed the ESPtools?
          • robskiR
            robski
            so you downloaded M5Burner correct? and it opens ok?
            what exact model of M5Stick you have - you need to choose correct firmware version.
            is your M5Stick com port detected in M5Burner when usb is plugged in to M5Stick?
            N 2 Replies Last reply Reply Quote 0
            • N
              Nooblearns @robski
              @robski Yes i downloaded M5 burner and Bruce. I have the M5 stick C plus
              • N
                Nooblearns @ajb2k3
                @ajb2k3 Esp tools I never downloaded.
                • N
                  Nooblearns @robski
                  @robski I downloaded M5 burner. I have bin, packages, and m5 burner. It's telling me to extract all files, I did that.
                  When I try and follow along with a video on this, my files don't look the same as in the videoIMG_4571 (1).jpg
                  N robskiR 2 Replies Last reply Reply Quote 0
                  • N
                    Nooblearns @Nooblearns
                    @Nooblearns I really appreciate your time and help!!
                    • robskiR
                      robski @Nooblearns
                      @Nooblearns just unzip in to folder before you run M5Burner
                      • N
                        Nooblearns @robski
                        @robski I deleted M5 burner and I am going to start again. Each time i extracted, nothing happened.
                        • N
                          @Nooblearns Let's goo, I think I am getting somewhere, thanks to you peeps!!!
                          • robskiR
                            robski @Nooblearns
                            @Nooblearns not a good start if M5Burner doesnt play game before you even connect your M5Stick
