    ATOMS3R accelerometer and gyro readings always 0
    Atom
    5
    7
    909
    • T
      toffifee
      Hi everyone,
      I bought an ATOMS3R, and burned the UIFlow2.0 ATOMS3R firmware on it. In UIFlow 2.0 I tried to print the accelerometer and gyroscope readings with below code.
      However, the readings are all zero regardless of how I move or shake the ATOM. Did I miss an initialization or calibration step?
      import os, sys, io
      import M5
      from M5 import *
      import time
      accel = None
      gyro = None
      def setup():
        global accel, gyro
        M5.begin()
      def loop():
        global accel, gyro
        M5.update()
        acc_x, acc_y, acc_z = Imu.getAccel()
        gyro_x, gyro_y, gyro_z = Imu.getGyro()
        print(f'accel: {acc_x}x, {acc_y}y, {acc_z}z')
        print(f'gyro: {gyro_x}x, {gyro_y}y, {gyro_z}z')
        time.sleep(1)
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      • kurikoK
        kuriko
        @toffifee
        have you tried Arduino example? we can determine if that was a hardware problem
        https://github.com/m5stack/M5AtomS3/blob/main/examples/Basics/imu/imu.ino
        • H
          hacxx Banned
          It looks like you're missing initialization for the IMU sensor. Try adding Imu.begin() inside the setup() function after M5.begin(). Without this, the sensor may not start properly, leading to zero readings. Also, ensure you're using the latest firmware and that the device isn't in USB mode, which can disable sensor updates.
            felmue @hacxx
            Hello @toffifee
            your code works for me using an M5AtomS3 (non R).
            That said, M5AtomS3 uses a different IMU chip (MPU68860) than M5AtomS3R (BMI270 / BMM150). So my best guess would be that UIFlow2 is not fully adapted to M5AtomS3R (yet).
            @hacxx : FYI @toffifee is using UIFlow2 - there is no Imu.begin().
            • T
              toffifee @kuriko
              Thanks for answering, guys.
              I tried the Arduino example as suggested by @kuriko and indeed I get non-zero readings! So maybe @felmue is right to assume that UIFlow2 doesn't fully support M5AtomS3R yet.
              The IMU readings don't make a lot of sense to me yet, I will next try to calibrate with this example code:
              https://github.com/m5stack/M5Unified/blob/master/examples/Basic/Imu/Imu.ino
              • teastainT
                teastain @toffifee
                @toffifee The raw outputs are beyond the ken of mortal man, except Accel which can easily be observed by placing it on a stationary level surface and observing that the accel values are stationary and one of the axes, usually Z is showing 1.00 (gravity).
                Roll it onto its side and the 1.00 should move to another axis.
                The other two outputs Gyro and Mag are best left to a positioning algorithm.
                • T
                  toffifee @teastain
                  @teastain thx for the hint! It's just as you said about acceleration.
                  Btw: UIFlow works. I just installed the incorrect firmware (UIFlow2.0 instead of UIFlow2.0 AtomS3R).
                  Thanks again everyone!
