    StamPLC - user demo- wifi/time config?
    PRODUCTS
    7
    2.3k
    • robskiR
      robski
      Received StamPLC with user demo project, updated to latest ver via M5Burner but there is no config to set up wifi or time. How can I do this when user demo is loaded? Uiflow2 firmware went in ok and there is "config" before burn so wifi ant time zone can be set thats ok. With user demo only timezone change is allowed from display.
      • robskiR
        robski @robski
        well just found EZData config/wifi setup so maybe thats the one to play with
          Mellie2025
          Hello robski,
          Did you manage to get the "EzData" demo to work?
          I received a STAMPLC recently and made a start with the preinstalled demo but i cannot get EzData to work correctly. Wifi setup went ok (eventually) along with the correct time zone so "Dashboard" shows a connection to EZData.
          Scanning the "Monitor Link" QR code takes me to a login page, and entering the correct credentials, briefly shows the EzData dashboard but quickly reverts back to the login page. The top right corner shows i am logged in but no joy in getting to the dashboard, repeatedly reverting back to the login page.
          I also updated the firmware to V0.2 with the same results.
          Hopefully there is a solution or am i missing something?
          • robskiR
            robski @Mellie2025
            @Mellie2025 yes EZdata works ok on mine, you have to log in with your M5stack credentials true, tried different web browser?
            I'm using firefox and it works ok.
            Can you maybe try to load Uiflow2 firmware and then bind it to your account and check if its visible as online device in your devices list.
              Mellie2025 @robski
              @robski Thank you, binding the device was the issue....DOH! Working now, much appreciated.
              O 1 Reply Last reply Reply Quote 1
              • O
                onlysaadat @Mellie2025
                @Mellie2025 hi there, when i try to open the ezdata link in login page says invalid token. whats the problem?
                • E
                  earla @onlysaadat
                  @onlysaadat My new StamPLC is exactly the same. Registered the device with M5Burner, It's on-line in UiFlow2, Loaded a fresh StamPLC demo - demo initially logged in and just flashed the monitor page no matter what browser is used on multiple computers. Cleared the monitoring user per M5s directions.
                  Now I get an invalid token no matter what I do.
                  Did you ever get your device to work with the demo or figure out how to fix the invalid token?
