    CoreMP135 install UiFlow2
    Cores
    6.7k
    • robskiR
      robski @MCU1536
      @MCU1536 have you enabled ssh in config?
        MCU1536 @robski
        @robski
        I tried the command as below result.
        My IP: 192.168.1.55
        Password: root
        ssh root@192.168.1.55
        root@192.168.1.55's password:
        sudo adduser good
        -sh: sudo: not found
        robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
        • robskiR
          robski @MCU1536
          @MCU1536 can you try putty via usb?
            MCU1536 @robski
            @robski
            I tried it on Putty via USB.
            Result is the same. It cannot add the user.
            • robskiR
              robski @MCU1536
              @MCU1536 how your initial boot screen looks like? in terminal.
                MCU1536 @robski
                @robski
                After I use latest M5_CoreMP135_debian12_20240919.
                I can install UiFlow2.
                Thank you very much for your help.
                  MCU1536 @MCU1536
                  After updated, I restart it. It hang up.
                  The Device Manager cannot find COM Port.
                  I tried to burn image for 2 time.
                  It still hang up.
                  root@CoreMP135:~# pip list
                  Package Version
                  certifi 2025.1.31
                  charset-normalizer 3.4.1
                  distro 1.8.0
                  evdev 1.9.1
                  idna 3.10
                  paho-mqtt 2.1.0
                  pip 23.0.1
                  PyAudio 0.2.14
                  pyserial 3.5
                  requests 2.32.3
                  setuptools 66.1.1
                  smbus2 0.5.0
                  uiflow2 0.0.1rc1
                  urllib3 2.3.0
                  wheel 0.38.4
                  root@CoreMP135:~# uiflow2
                  UIFlow2 running PID: 2974
                  root@CoreMP135:~# uiflow2 enable
                  Created symlink /etc/systemd/system/multi-user.target.wants/uiflow2.service →
                  /etc/systemd/system/uiflow2.service.
                  enable uiflow2 service success
                  root@CoreMP135:~#
                  • robskiR
                    robski @MCU1536
                    @MCU1536 thats my pip list
                    uiflow2 works
                    Package Version
                    bcrypt 4.3.0
                    certifi 2025.1.31
                    cffi 1.17.1
                    cryptography 44.0.2
                    dbus-python 1.3.2
                    distro 1.8.0
                    distro-info 1.5+deb12u1
                    evdev 1.9.1
                    idna 3.10
                    paho-mqtt 2.1.0
                    paramiko 3.5.1
                    parse 1.20.2
                    pexpect 4.9.0
                    pip 23.0.1
                    ptyprocess 0.7.0
                    PyAudio 0.2.14
                    pycparser 2.22
                    PyGObject 3.42.2
                    PyNaCl 1.5.0
                    pyserial 3.5
                    python-apt 2.6.0
                    requests 2.32.3
                    SCons 4.9.1
                    scp 0.15.0
                    setuptools 66.1.1
                    smbus2 0.5.0
                    ufw 0.36.2
                    uiflow2 0.0.1rc1
                    unattended-upgrades 0.1
                    urllib3 2.3.0
                    wheel 0.38.4
                      ajb2k3 @MCU1536
                      @MCU1536 For some reason the sudo command isn't installed by default.
                      By default roots SSH is disabled you need to create a new use and enable SSH on that account.
                      You then need to download the file from the website and copy it to the coreMP135 and run it from there.
                        MCU1536 @ajb2k3
                        After burned with M5_CoreMP135_debian12_20240919.img
                        Don't restart the MCU.
                        I tried the commands as below.
                        1. root@CoreMP135:~# sudo service ssh start
                        2. root@CoreMP135:~# sudo adduser good
                        3. ifconfig
                          eth0: inet 192.168.1.45
                          root@CoreMP135:~# ssh good@192.168.1.45
                        4. CoreMP135 Partition Resize
                        After reboot the MCU.
                        The MCU can boot-up.
                        Thank you for very much for your help.
