    Atom display not working
    Atom
    1.3k
    • A
      Acuario
      I am trying to get my AtomDisplay HDMI working without success.
      The factory demo worked fine.
      I have tried the basic example but I get nothing.
      The odd thing is the display says it has 0 width and height.
      Here is my code:
      #include <Arduino.h>
      #include <M5AtomDisplay.h>
      M5AtomDisplay display(1280, 720, 50); // width, height
      void setup(void)
      Serial.begin(115200);
      // initialize
      display.init();
      Serial.printf("W:%d H:%d\n", display.width(), display.height());
      The serial output shows W:0 H:0 so it seems the display is not initialised correctly.
      The same occurs when I try the default (no parameters), both are 0.
      I enables logging on the ESP and the log shows the following errors so I guess this is why. Is my AtomDisplay broken or an old version that is no longer supported?
      Opening port
      Port open
      [ 16][D][esp32-hal-cpu.c:264] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
      =========== Before Setup Start ===========
      Chip Info:
      Model : ESP32
      Package : PICO-V3-02
      Revision : 3.00
      Cores : 2
      CPU Frequency : 240 MHz
      XTAL Frequency : 40 MHz
      Features Bitfield : 0x000000b3
      Embedded Flash : Yes
      Embedded PSRAM : Yes
      2.4GHz WiFi : Yes
      Classic BT : Yes
      BT Low Energy : Yes
      IEEE 802.15.4 : No
      INTERNAL Memory Info:
      Total Size : 382032 B ( 373.1 KB)
      Free Bytes : 351188 B ( 343.0 KB)
      Allocated Bytes : 23632 B ( 23.1 KB)
      Minimum Free Bytes: 345420 B ( 337.3 KB)
      Largest Free Block: 114676 B ( 112.0 KB)
      Flash Info:
      Chip Size : 8388608 B (8 MB)
      Block Size : 65536 B ( 64.0 KB)
      Sector Size : 4096 B ( 4.0 KB)
      Page Size : 256 B ( 0.2 KB)
      Bus Speed : 80 MHz
      Bus Mode : DIO
      Partitions Info:
                  nvs : addr: 0x00009000, size:    20.0 KB, type: DATA, subtype: NVS
              otadata : addr: 0x0000E000, size:     8.0 KB, type: DATA, subtype: OTA
                 app0 : addr: 0x00010000, size:  1984.0 KB, type:  APP, subtype: OTA_0
                 app1 : addr: 0x00200000, size:  1984.0 KB, type:  APP, subtype: OTA_1
             coredump : addr: 0x003F0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
      Software Info:
      Compile Date/Time : Mar 26 2025 11:22:10
      Compile Host OS : windows
      ESP-IDF Version : v5.1.4-972-g632e0c2a9f-dirty
      Arduino Version : 3.0.7
      Board Info:
      Arduino Board : ESP32_DEV
      Arduino Variant : esp32
      Arduino FQBN : esp32:esp32:esp32:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=no_fs,DebugLevel=debug,PSRAM=disabled,LoopCore=1,EventsCore=0,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default,fsupload=littlefs
      ============ Before Setup End ============
      [ 526][D][m5atomdisplay.h:153] init_impl(): [LGFX] pkg:6
      [ 531][I][panel_m5hdmi.cpp:506] init(): [M5HDMI] i2c port:1 sda:25 scl:21
      [ 539][I][panel_m5hdmi.cpp:511] init(): [M5HDMI] Chip ID: 17 02 e2
      [ 546][I][panel_m5hdmi.cpp:517] init(): [M5HDMI] Resetting HDMI transmitter...
      [ 560][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:81
      [ 569][I][panel_m5hdmi.cpp:500] _read_fpga_id(): [M5HDMI] FPGA ID:48440004
      [ 576][I][panel_m5hdmi.cpp:500] _read_fpga_id(): [M5HDMI] FPGA ID:48440004
      [ 583][D][panel_m5hdmi.cpp:714] _init_resolution(): [M5HDMI] PLL feedback_div:1 input_div:1 output_div:8 OUTPUT_CLOCK:74250000
      [ 594][D][panel_m5hdmi.cpp:715] _init_resolution(): [M5HDMI] logical resolution: w:1280 h:720
      [ 603][D][panel_m5hdmi.cpp:716] _init_resolution(): [M5HDMI] scaling resolution: w:1280 h:720
      [ 611][D][panel_m5hdmi.cpp:717] _init_resolution(): [M5HDMI] output resolution: w:1280 h:720
      [ 620][D][panel_m5hdmi.cpp:718] _init_resolution(): [M5HDMI] video timing(Hori) total:1980 active:1280 frontporch:344 sync:26 backporch:330
      [ 632][D][panel_m5hdmi.cpp:719] _init_resolution(): [M5HDMI] video timing(Vert) total:750 active:720 frontporch:14 sync:1 backporch:15
      [ 644][I][panel_m5hdmi.cpp:580] init(): [M5HDMI] Initialize HDMI transmitter...
      [ 659][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 675][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:82
      [ 691][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:2b val:00
      [ 708][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:2e val:00
      [ 723][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 742][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 761][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 780][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 799][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 818][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 836][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 855][I][panel_m5hdmi.cpp:332] writeRegister(): [M5HDMI] i2c write err reg:ff val:80
      [ 867][E][panel_m5hdmi.cpp:439] init(): [M5HDMI] failed to initialize the HDMI transmitter.
      [ 875][W][panel_m5hdmi.cpp:583] init(): [M5HDMI] HDMI transmitter Initialize failed.
      W:0 H:0
      =========== After Setup Start ============
      Free Bytes : 348164 B ( 340.0 KB)
      Allocated Bytes : 26176 B ( 25.6 KB)
      Minimum Free Bytes: 342020 B ( 334.0 KB)
      GPIO Info:
      GPIO : BUS_TYPE[bus/unit][chan]
       1 : UART_TX[0]
       3 : UART_RX[0]
      ============ After Setup End =============
