    IMU Pro Mini Unit fails to Init on Core2
    Units
    1.2k
    • C
      ChrisFSB
      Summary
      Using a U171 IMU Pro Mini with Core2, the U171 fails to initialize, returning error:
      OSError: [Errno 19] ENODEV
      Repro Steps
      Initialize the bus and U171
      i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
      print(i2c0.scan())
      imupro_0 = IMUProUnit(i2c0)
      i2c0.scan() returns BMI270 (0x68) and BMP280 (0x76); the BMM150 is behind the BMI270.
      Trace for the constructor's failure is :
        File "main.py", line 24, in <module>
        File "main.py", line 17, in setup
        File "unit/imu_pro.py", line 36, in __init__
        File "driver/bmi270_bmm150.py", line 720, in __init__
        File "driver/bmi270_bmm150.py", line 539, in __init__
        File "driver/bmi270_bmm150.py", line 622, in _write_reg
      Looking at the underlying code :
      Constructor calls:
      super().__init__(i2c, address=bmi270_address, aux_address=address)
      Which does a soft reset, then attempts to write a register:
      # Perform initialization sequence.
      # 0.Soft-reset
      self.soft_reset()
      # 1.Disable power save mode.
      self._write_reg(PWR_CONF, 0x00)
      time.sleep_ms(10)
      The write fails:
      self._i2c.writeto_mem(self.address, reg, val)
      I patched the following and added i2c0.scan() after each i2c write:
      IMUProUnit.soft_reset
      IMUProUnit._write_reg
      IMUProUnit.new_write_burst
      Scanning the bus after each write, stops the ENODEV error. However init never completes.
      Any ideas how to get U171 to work?
      • C
        ChrisFSB @ChrisFSB
        @ChrisFSB Any ideas here folks? Thx!
