    Step Motor Module
    20 Posts 3 Posters 42.6k Views 1 Watching
      ajb2k3 @cepics
      @cepics said in Step Motor Module:
      thanks, I will try with NEMA 17 12v.....
      You will need to adjust the drivers as they are not calibrated by default.
        cepics
        thanks, some link to study waiting for goods?
          only this
          link text
          I have shared my sample code but my documentation need big work.
            BTW, you are aware that its the new year and everything is shut down thill the 12th?
              cepics
              @ajb2k3 said in Step Motor Module:
              How can I calibrate the drivers?
              Can I Use this motor?
              • Angle of step: 1.8 degrees.
              • Voltage: 12 V
              • Current: 1.2 A / phase.
              • Resistance: 10.0 ± 10% / phase.
              • inductance: 20 ± 20% / phase.
              • Support moment: 68 g / cm2.
              • Number of wires: 4
              • Support time: 48 min. N. cm.
              • Large braking torque: 2.6 N. cm.
              • Insulation class: B
                Ebay link?
                Calibration is done via the tiny silver round thing on the individual stepper driver.
                  cepics
                  Ebay link?
                  NEMA 17 MOTOR
                  thanks a lot !!
                  something like this ?
                    Yes, just like that.
                    Don't connect any steppers when calibrating it!
                      cepics
                      NEMA 17 MOTOR
                      can I use this motor with the step motor module?
                      can I power the core and the module with 12v ?
                        ajb2k3 @cepics
                        @cepics
                        yes the nema 17 will be fine.
                        I'm sure that the m5 will receive power from the module but i'm not certain.
                        you will need external power to the module to power the stepper.
                          cepics
                          I will try ....
                          thanks
                            Kryten
                            @ajb2k3 Do you have any good scource for wires for the stepper output?
                            I have several sets of stepper motor wires but none that fit in the stepper module
                              ajb2k3 @Kryten
                              @kryten the stepper module uses the standard Grove cable system so cutting off the existing wire connections on the stepper motor and replacing them with a grove wire harness works fine for me.
                                Kryten @ajb2k3
                                Thank you very much.
                                I hope to get some wires sorted out soon so I can see if I manage to get the module working on a "printer" (2D drawings)
                                  ajb2k3 @Kryten
                                  @kryten said in Step Motor Module:
                                  My pleasure
                                    cepics
                                    can I use this motor with this module?
                                      ajb2k3 @cepics
                                      It looks like it should work but you would need to adjust the drivers. I don’t have one so I can’t say for certain but it is a 4 wire stepper
