    ACSSR and LED Floodlight (Spotlight) is not switching off
    Units
    • E
      Erik_
      if i connect the ACSSR unit with a LED Floodlight (30W) or Spotlight (100W) (and 220V), there are some Leds light up, even if i change phase and neutral conductor.
      If i connect the ACSSR with a M5Stack Basic Core and run this program, there are the same Leds light up, if i send SSR.off:
      #include <M5Stack.h>
      #include <Wire.h>
      #include "M5_ACSSR.h"
      M5_ACSSR SSR;
      void setup()
      Wire.begin();
      Serial.begin(115200);
      while (!SSR.begin(&Wire, 21, 22, ACSSR_DEFAULT_ADDR)) {
      Serial.println("ACSSR I2C INIT ERROR");
      delay(1000);
      Serial.print("FW Version: 0x");
      Serial.println(SSR.getVersion(), HEX);
      SSR.on();
      Serial.print("ACSSR STATUS: ");
      Serial.println(SSR.status());
      SSR.setLEDColor(0xff0000);
      Serial.print("LED COLOR: 0x");
      Serial.println(SSR.getLEDColor(), HEX);
      delay(900);
      SSR.off();
      SSR.setLEDColor(0x00ff00);
      delay(900);
      The green and red Button Leds are changing from red to green and the 3V~32VDC Led is turning on and off, but at SSR.off some Leds at the Floodlight are light up.
      So the ACSSR is not disconnecting the power completely to the floodlight in SSR.off.
      Even, as i mentioned before, i change phase and neutral conductor of the 230V power.
