    noting shows on m5stick and unable to connect to pc
    M5 Stick/StickC
    588
    • H
      Hristak
      can someone help me fix my m5stick plus 2
      kurikoK ajb2k3A 2 Replies Last reply Reply Quote 0
      • kurikoK
        kuriko @Hristak
        @Hristak
        have you tried replacing a cable?
        • robskiR
          robski
          when you open M5burner and you connect USB to your M5StickC+2 can you see com port number popup in top right corner of M5burner?
          if so then download latest firmware for your M5StickC+2, hit erase, then burn
            ajb2k3 @Hristak
            @Hristak Is it charged?
            Have you checked that you are using a working data cable and not a charge cable?
            Did you erase firmware before burning new?
            Did you select the correct firmware version?
            What computer are you using?
            What OS are you using?
