    UiFlow 2.0
    74
    188
    408.4k
    • Coopersmith-24601C
      Coopersmith-24601
        Coopersmith-24601
        FEATURE REQUEST!
        It would be extraordinarily helpful for there to be a type of LABEL in UiFlow2 which could fill the screen and word-wrap long text strings.
        • IAMLIUBOI
          IAMLIUBO @Coopersmith-24601
          @Coopersmith-24601 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
          FEATURE REQUEST!
          Yes. Thanks for suggestion. We will consider this.
          • C
            Calvorotas
            I am trying to receive a bytearray via BLE from a server, but I can't get a response.
            By sending a certain bytearray via BLE to the Sbrick device, it returns a response indicating the temperature value. And through another bytearray, the voltage value is returned.
            In App Inventor I get it with these blocks:image-1.png image-2.png
            But in UiFlow 2.0 I can't get it using these blocks:
            What am I doing wrong?
            s it possible that this block will not trigger the server response?
            Perhaps, the mode argument is mode=0 (write-without-response). Or am I mixing up different things?
            I can't get a response from the server with the "When BLE client on notify" block or with the "When BLE client on read complete" block
            I need help, or a lot of help. :)
            Thank you very much.
            • greenleafG
              greenleaf
              Feature request:
              Ability to set headers for Label+ objects. Many APIs required these headers before they respond with proper JSON.
              Example:
              curl -H "Accept: application/json" https://icanhazdadjoke.com/
              • R
                Rango
                I'm using a MiniJoyC with M5stuckC Plus2 and UIFlow 2.1.4.
                I've read through examples and documentation but I can not get x or y values. They only display 0.
                Same thing happens in Arduino IDE.
                I do get values when using UI flow 1, so I know the minijoy is working.
                Any known issues with the UIf2 libraries?
                Thanks in advance.
                • G
                  gbelfor
                  Using: UIFlow 2.1.5, AtomS3, KMeterISOunit
                  From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:
                  Code generated (snipit)
                  ...but from the latest API docs, the reading code should be:
                  Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
                  • X
                    xs
                    Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
                    • X
                      xs @xs
                      @xs Also, Servo2 module isnt sopported
                        A Former User
                        Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
                        cryptospokC 1 Reply Last reply Reply Quote 1
                        • cryptospokC
                          cryptospok
                          I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
                          • cryptospokC
                            cryptospok @A Former User
                            • R
                              riztronic
                              missing magnetometer scratch code for atom s3r , please add
                              kurikoK teastainT 2 Replies Last reply Reply Quote 0
                              • kurikoK
                                kuriko @riztronic
                                @riztronic
                                did you mean a built-in magnetometer?
                                • teastainT
                                  teastain @riztronic
                                  @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                                  • C
                                    Calilov330000
                                    Does anyone know how to connect my m5stack core 2 ?
                                    Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                                    • kurikoK
                                      kuriko @Calilov330000
                                      @Calilov330000
                                      why don't you try a simple laptop/desktop?
                                      • D
                                        Davidalan5757
                                        Could you unlock from UIFlow 2 the capability to code in micropython…
                                        • J
                                          jpilarski
                                          I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                                          • C
                                            charlesRD
                                            I have some difficulties to burn UIFLOW on new devices
                                            For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                                            I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                                            It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                                            The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                                            it looks like i am not able anymore to have the same atom running when i burn them today.
                                            Did i forgot something ?
                                            Thank you very much,
                                            Charles
