    ATOM S3 - Problems writing IMU Registers
    General
    • H
      hriq105
      I'm currently developing a solution for acceleration data extraction with the M5Stack ATOM S3 module which already includes a MPU 6886 IMU sensor. In its datasheet I'm told it is capable of reaching 4 kHz of sampling rate for the accelerometer. However, while trying to change the registers in what I thought would be the correct settings for highest performance in terms of sampling speeds, it always outputs acceleration in the range of +-8 g and with sampling speed of 250Hz. This is true for any register values I write. Thus, I suspect the writing of such registers is being wrongly handled.
      My questions are:
      • Is there any library that handles the writing of these registers without fail?
      • Am I choosing the right register addresses and new values?
      I also add here a portion of my code corresponding of the writing of the IMU registers:
      // Setup for IMU
      void setupIMU() {
          Wire.begin();
          writeRegister(0x6B, 0x09);  // Wake up MPU6886
          delay(10);
          writeRegister(0x1C, 0x18);  // Set accelerometer to ±16g
          delay(10);
          writeRegister(0x1D, 0x08);  // Disable Low-Pass Filter (more noise)
          delay(10);
          writeRegister(0x6C, 0x07);  // Disable gyroscope
          delay(10);
          writeRegister(0x1B, 0x03);  // Set gyroscope configuration (if needed)
          delay(10);
      void writeRegister(uint8_t reg, uint8_t value) {
          Wire.beginTransmission(0x68);  // MPU6886 I2C address
          Wire.write(reg);               // Register address
          Wire.write(value);             // Value to write
          Wire.endTransmission();        // End transmission
        Serial.begin(115200); // Initialize serial communication at 115200 baud rate
        while (!Serial); // Wait for serial to initialize
        auto cfg = M5.config();
        setupIMU();
      Thank you
      • H
        hriq105 @hriq105
        @hriq105
        I found the answer to my problem of writing on the IMU registers on another post here:
        https://community.m5stack.com/topic/6959/finding-imu-3d-example-code
        However, I'm still having some problems with finding out how to set them up to get the full 4 kHz of acceleration data mentioned in the datasheet. If anyone knows this, please let me know.
