MQTT UIFlow problems
Very sorry, we will fix it today,
@heybin thank you, this evening i will try...
also, if i can, i think then the image used to insert text, label etc...in the m5 is too little -
@heybin said in MQTT UIFlow problems:
Has it been fixed yet? I'm trying the example, but after downloading the MQTT example flow to my m5stack Fire, it just freezes. It is not responsive until I reset it.
https://m5stack.github.io/UIFlow_doc/cn/zh_CN/MQTT/Example.html
My flow:
cloudmqtt settings:
Here are the logs from cloudmqtt.com. Not sure how to resolve the socket error.
2019-01-22 19:07:18: mosquitto version 1.5.5 starting
2019-01-22 19:07:18: Config loaded from /var/lib/mosquitto/19639/mosquitto.conf.
2019-01-22 19:07:18: Opening ipv4 listen socket on port 29639.
2019-01-22 19:07:18: Opening websockets listen socket on port 39639.
2019-01-22 19:07:18: Opening ipv4 listen socket on port 19639.
2019-01-22 19:09:09: New client connected from 64.100.78.39 as cloudmqtt-st-ui-0.9613626986254669 (c1, k60, u'oklhhzzb').
2019-01-22 19:09:10: Socket error on client cloudmqtt-st-ui-0.9613626986254669, disconnecting.
2019-01-22 19:09:11: New client connected from 64.100.78.39 as cloudmqtt-ws-ui-0.6445892594600325 (c1, k60, u'oklhhzzb').
2019-01-22 19:10:05: Client cloudmqtt-ws-ui-0.6445892594600325 disconnected. -
What Operating system do you use?
What M5 are you using? -
@dvd78 said in MQTT UIFlow problems:
also, if i can, i think then the image used to insert text, label etc...in the m5 is too littleUse the internet browsers zoom function.
@ajb2k3 said in MQTT UIFlow problems:
What M5 are you using?I'm on a Mac with OS 10.13.6 (High Sierra).
I have the m5stack Fire (red) hardware running v1.1.1.Is MQTT working for you?
Yes, but I'm worried about the restarting.
I only have an M5Core -
I have a m5stack grey as well that I will try tonight.
i have an M5core too but mqtt is not working yet
@dvd78 Update firmware to 1.1.1 to get MQTT working.
i did it yesterday, do i need to download a new version?
@dvd78 Sorry, yesterday our engineers forgot to update....
now, already fixed, refresh web page it will be ok -
MQTT working good for me now with both of my grey and fire m5stack cores. I have tested cloudmqtt and io.adafruit. Thanks for fixing it!
@heybin thank you, problem is solved.
bye
I tried the same blocky today. It uploaded but on the display I only see: error ImportError('mqtt need download...'.)
I am using an M5Stack Fire, firmware 1.1.2.
I have a local MQTT broker running on an Onio Omega and the upload is done with a Windows 10 computer.Any help would be appreciated.
Instead of running the program directly from uiFlow (which is the triangle button at the top-right), just click the Download option from the hamburger menu.
Thanks! That worked.
Just out of curiosity: What's the difference between the two? -
@the_stacker said in MQTT UIFlow problems:
Just out of curiosity: What's the difference between the two?Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
