    Problems with the Labels
    UIFlow
    16
    28.1k
      ajb2k3 @gadjet
      @gadjet
      I'm getting the same.
      • G
        gadjet @ajb2k3
        @ajb2k3 said in Problems with the Labels:
        @gadjet
        So it looks like it's a problem with the UiFlow interface then, is it a known bug?
          ajb2k3 @gadjet
          @gadjet said in Problems with the Labels:
          @gadjet
          @heybin do you know about this bug?
          • H
            heybin
            I have met this, but I don’t know how to reproduce it,Can you describe how to trigger?
            ajb2k3A G 2 Replies Last reply Reply Quote 0
              ajb2k3 @heybin
              @heybin said in Problems with the Labels:
              Will see If I reproduce the steps I took to cause the bug later.
                I have added a few extra font changes to trigger the bug but its the first set font that is triggering "Font not defined."
                alt text
                UIFlow and firmware 1.1.1
                • H
                  heybin
                  this bug will fix in those day, but gadjet said looks like another bug...
                    The ghosting, i think, is to do with the lcd screen,
                    I made guess that he was using the deja vue and trying to set it with the different size specific block.
                    • G
                      gadjet @ajb2k3
                      I did some more work and found the ghosting is when I modify a label, when I leave the label and then use LCD.Print to add the text is seems to be OK.
                      I was mistakenly using the label object to write a changing value to the screen, LCD.print works OK but editing the label would still give the ghosting issue.
                      • G
                        gadjet @heybin
                        I have a suspicion that it happens after the code has been downloaded and you try to edit the labels, a reload of the page and the project fixes it.
                        I will test out my theory tonight and feedback.
                        • world101W
                          world101 @gadjet
                          Where is LCD.print in UIFlow? Is it the print block under the Text menu?
                            ajb2k3 @world101
                            @world101 lcd.print is a micropython command, you use the Label show block which is the first block I put under the setup bock in the screen grab I posted above.
                            • G
                              gadjet @world101
                              @world101 It's in the "Graphic" group
                              ![LCD.Print](image url)
