    M5StickC : how to switch 5V out off?
    M5 Stick/StickC
    4.9k
    • KabronK
      Kabron @HappyUser
      Join the question
      Obviously EXT_VDD is enabled via EXT_BOOST_EN pin of the AXP192, so it must be a way to control it.
        felmue @Kabron
        Hello @HappyUser
        you can use this function to control the output of 5 V out (and Groove port):
        M5.Axp.SetPeripherialsPower(true or false);
        KabronK 2 Replies Last reply Reply Quote 2
        • KabronK
          Kabron @felmue
          • KabronK
            Kabron
            I tested it - does not work at all
            • KabronK
              Kabron @felmue
              @felmue It only switched 5V to Vbatt
              I see the only way to reconnect EXT_BOOST_EN of the BOOST converter to VESP_3V3.
                felmue @Kabron
                Hello @Kabron
                hmm, I've tested with an M5StickC (not Plus, not Plus2) powered by USB-C (or battery) and an LED attached to the Groove port.
                I agree, EXT_BOOST_EN needs to be turned on, which is exactly what the function I pointed out does. It sets bit 2 of register 0x10 of the AXP. See here. And here - page 34.
                Edit: I just remembered, I think there was a similar discussion a couple of years ago. EXTEN actually seems to exist in two places. Bit 2 in register 0x10 and bit 6 in register 0x12.
                Maybe try to manipulate bit 6 in register 0x12 to see if that works for you?
                • KabronK
                  Kabron @felmue
                  @felmue I tested it:
                  void AXP192::SetPeripherialsPower(uint8_t state) {
                  if (!state){
                  Write1Byte(0x10, Read8bit(0x10) & 0XFB);
                  Write1Byte(0x12, Read8bit(0x12) & 0XBF);
                  else if (state) {
                  Write1Byte(0x10, Read8bit(0x10) | 0X04);
                  Write1Byte(0x12, Read8bit(0x12) | 0X40);
                  EXT_BOOST_EN controlled correctly, DC-Boost stops generating, but bypassed input Vbatt to 5V output.
                  What an idiot designed this part of schematic?
                  I could not identify DC-Boost IC(Sot-23-5 marked IB3KB)/
                  • KabronK
                    Kabron
                    So, according to schematic switching off 5V is fundamentally impossible. IPSOUT via L1 and D3 allways present at output.
                      felmue @Kabron
                      Hello @Kabron
                      I start to think that maybe the DC/DC IC has been changed over time in the M5StickC. The DC/DC IC in mine is marked SCAJF and the externally connected components look suspiciously like the 5VOUT_BOOST in the M5StickCPlus schematic.
                      This would at least explain the different results regarding on/off capability.
                      • KabronK
                        Kabron
                        Definitelly, M5SticC and M5SticC Plus have different schematics. DC-Boost in M5SticC Plus is sgm6603-5.
                          felmue @Kabron
                          Hello @Kabron
                          I beg to differ. At least between my M5StickCPlus and M5StickC the DC/DC boost circuit and IC look suspiciously identical.
                          on the left: M5StickCPlus; on the right: M5StickC
                          • KabronK
                            Kabron @felmue
                            @felmue I draw schematic above from my exemplar. Obviously it's too old.
                            IC is SOT-23-5 and its marking corresond with MP1541 datasheet.
                            The root of the evil is M5STACK's absolutely lackadaisical documentation for all the products.
