    MQTT
    UIFlow
    5
    26
    110.0k
      Nice, can't wait to play.
      • J
        jpilarski
        I am using IFTTT with webhook based on an ok google "turn light on" and "turn light off" command. That message is relayed to io.adafruit and then transmits back to m5stack which performs a function based on the string received. Optionally data can also be sent to the cloud from the board using publish topic.
        G ajb2k3A 2 Replies Last reply Reply Quote 1
        • G
          gadjet @jpilarski
          @jpilarski Thanks for that I'll give it a go.
            ajb2k3 @jpilarski
            @jpilarski said in MQTT:
            IS this the full code?
            Doesn't do anything for me :(
            • J
              jpilarski
              You have to save the file to your board. Don't use run. Once it reboots it will connect to wifi and then run the mqtt blocks.
              ajb2k3A D 2 Replies Last reply Reply Quote 0
              • G
                gadjet
                Well initially I got this working a treat but then made some changes and downloaded it and it stopped working ??? not sure what's going on.
                I made a simple program to switch neopixel led to R, G and B from the three switches, when I run it using the play button it works, when I download it only one button works, I suspect there is something not working quite right when downloading the program.
                  ajb2k3 @jpilarski
                  Are you running the 1.1.1 firmware as I don't have label appearing on the screen?
                  • G
                    gadjet @ajb2k3
                    @ajb2k3 Yes I am using firmware 1.1.1.
                    The first thing I was doing in mine was adding a title and updating the text of the title, I removed this and now it seems to work OK.
                      ajb2k3 @gadjet
                      @gadjet ah that explains it, I’m still running 1.0 as I haven’t had the time to update devices yet.
                        Sarcasm funny that it works after the update Sarcasm
                        Thanks, Gadget, can I use this demo in my book.
                        still cant get the neopixel to work
                        • G
                          gadjet @ajb2k3
                          @ajb2k3 I'm using this flow and it works with a single RGB LED plugged in the grove port A
                          RGB LED Flow
                          Last night it would only work with the play button and not the download option, now it works with both ???
                            ajb2k3 @gadjet
                            @gadjet
                            Ok something is missing that set the topic to on or off.
                            • G
                              gadjet @ajb2k3
                              @ajb2k3 said in MQTT:
                              @gadjet
                              Do you mean in the image I posted? that's just a flow to switch a neopixel LED on/off, no MQTT intervention.
                                ajb2k3 @gadjet
                                @gadjet
                                Hmn, I need to play then.
                                • D
                                  dvd78 @jpilarski
                                  Hi @jpilarski, how can i save the file? don't i only need to do "download" from "http://flow.m5stack.com"?
                                  i have a project working great if i download it from http://flow.m5stack.com, but when i reboot the M5Stack my module won't start...
                                  Best
                                  Davide
                                    ajb2k3 @dvd78
                                    @dvd78 said in MQTT:
                                    Best
                                    Davide
                                    You need to connect you M5 to UIFlow, click the download button (a rough WIP guide is in my WIP Handbook on pages 7, 8, and 9)
                                    You need to click the 3 horizantal lines to get the settings up and then click download.
                                    When the M5 Stack restarts you need to hit the middle button (B) to get the app list then use the right button (C) to move down and then B to run the program.
                                    • D
                                      dvd78
                                      thank you @ajb2k3... is there a way to start the m5 immediately with your program?
                                        ajb2k3 @dvd78
                                        @dvd78 I think.....
                                        If you just power it on it should autoload the program.
