    M5stickC Plus 2 connecting SD card Module not working
    General
    5.8k
    • W
      WH1T3_01L
      I'm trying to run NEMO or Marauder using an SD card module at 3.3V made specifically for the ESP32 but even tho i followed the right wiring (Displayed below) Neither of them seem to be able to initialise my SD card.
      Wiring:
      M5 --> SD
      GND --> GND
      3.3v --> 3.3v
      G0 --> CLK
      G26 --> MISO
      G32 --> MOSI
      None --> CS
      (Wiring found in https://community.m5stack.com/topic/5290/my-m5stickc-plus-can-t-read-micro-sd/3)
      Does somebody know what the issue might be?
      • L
        LEFTIPAN @WH1T3_01L
        @wh1t3_01l CS must be connected somewhere. I don't know the answer, but I know that without CS you can't have the SD card breakoutboard working.
        • F
          flypeek
          https://forum.m5stack.com/topic/1002/how-to-connect-sd-card-to-m5stickc
          • R
            roddpap
            Here is how I made it work:
            • CS Connects also to GND in M5.
            • Some Card adapters requires 5V to work (bigger ones)
            • Card must be formatted as FAT32
            • SD card capacity <=32G
