    Centering A Label in M5Stack Core S3
    UiFlow 2.0
    1.4k
      mehulge
      Hi, Just looking for a simple function or code to center the text inside Core S3 for UiFlow Micropython.
      Widgets.Label doesn't have any centering as far as I can tell.
      • C
        Cognitive5525
        Statically you can center a label in the UI-editor.
        Dynamically not so easy as far as I can see, because there is no way to get the width and height of a particular string. If your program is only outputting a known set of strings you could make a small table (dictionary or similar) with the "center coordinates" for each string....
