    UiFlow 2.0
    73
    186
    382.6k
    • Z
      zendes
      Hi. I'm missing the 4-Relay Unit in the list of possible devices. Can you please add that back, as it exists in uiflow 1?
        Hello @zendes
        maybe my example (PlayZone: M5Dial_4RelayUnit_UIFlow2.0.1) can help out until the native 4-relay unit gets added in UIFlow2.
        Note: you might need to modify the I2C pins for SCL and SCK dependent on the core you are using.
          sorphin
          1_1712280273337_Screen Shot 2024-04-04 at 6.22.56 PM.png 0_1712280273336_Screen Shot 2024-04-04 at 6.24.02 PM.png
          • W
            wmatkins
            @dlhawley
            These are current products for sale in the M5 store. Wasn't the NCIR-2 introduced over two years ago? I think there would have been ample time to integrate them into the latest UIFlow.
              Hello @wmatkins
              re: NCIR hat : I think it should work by adding the NCIR unit but with a custom I2C setting, e.g. SCL=26 and SDA=0.
              Note: I do not have the NCIR hat or unit so I cannot test this myself.
                Hello @sorphin
                I can confirm that in M5Dial UIFlow2.0.3 firmware the blocks for the built-in RFID reader are not working and throw an error. However, as a workaround, I used the blocks of a virtual RFID unit (and modified I2C SCL and SDA pins) to successfully read RFID cards with the internal RFID reader. See PlayZone M5Dial_RFID_UIFlow2.0.3 example.
                  sorphin @felmue
                  @felmue Thanks for confirming as well Felix. I did find that I could make it work in a round about way as well (using rfid.RFID (no parenthesis)).. but one shouldn't have to do that :/
                  • CAT the TechC
                    CAT the Tech
                    I have 3 issues currently:
                    • 1
                      This is very fast (less than a minute).
                      When I use UiFlow 2.0's web interface to upload my program (~20KB) via USB in the web terminal, however, It is very very slow (~2-3 minutes).
                      The issue also happens when I upload a file from the web terminal.
                    • 2
                      When I upload a file or program, it results in an empty (0 Bytes) file! (most of the time), I burned the old Alpha-29 version of UIFlow 2 on my device using M5Burner, and this problem is fixed
                    • 3
                      Half of the time, when I run the program, the colors are inverted (instead of RGB, it's BGR, literally)
                    • P
                      Peter
                      I would like to use the touchscreen on the M5Dial. But the block M5.Touch.getCount() does not work in a while loop! It only works in the main loop. So the touchscreen is hardly usable in Micropython. I have not been able to realize the waiting for a touch.
                        Hello @Peter
                        the trick is to add an M5.update() statement (using an Execute mpy Code block) inside the while loop.
                        See UIFlow2 Project Zone example: M5Dial_Touch_Get_Count_In_While_Loop_UIFlow2.0.4
                        • P
                          Peter @felmue
                          @felmue Thanks Felix, it works:)
                          I didn't look to the Project Zone. I'll do it now.
                          • R
                            Raed.Alnuaimi
                            Hi...
                            How to add custom block (m5b) to UiFlow2.0???
                            • H
                              HéctorD
                              Is there any way to port projects from UiFlow 1 to UiFlow 2 (.m5f to .m5f2)?
                              I've been searching in the forum but didn't find any message about it.
                              I've to start all my development from zero or there is any way to port projects from one system to the another?
                              I've several developments for M5StickC.
                              If it is possible, I think it must be put more visible how to do it. If it's not possible, it must be warning in some place to be visible too.
                              Thanks.
                              • CAT the TechC
                                CAT the Tech
                                Since update 2.0.9, the buttons on my M5Stack Stick C Plus 2 have been tangled and unusable
                                The button A and power button (aka button C) are now unresponsive. Their respective callbacks do not get triggered at all.
                                The button B will trigger the callback for button A!
                                Here is my test program:
                                import os, sys, io
                                import M5
                                from M5 import *
                                from hardware import *
                                import time
                                def btnA_wasPressed_event(state):
                                  print('Pressed A')
                                def btnA_wasReleased_event(state):
                                  print('Released A')
                                def btnB_wasPressed_event(state):
                                  print('Pressed B')
                                def btnB_wasReleased_event(state):
                                  print('Released B')
                                def btnPWR_wasPressed_event(state):
                                  print('Pressed PWR')
                                def btnPWR_wasReleased_event(state):
                                  print('Released PWR')
                                def setup():
                                  print('hello M5')
                                  M5.begin()
                                  BtnA.setCallback(type=BtnA.CB_TYPE.WAS_PRESSED, cb=btnA_wasPressed_event)
                                  BtnA.setCallback(type=BtnA.CB_TYPE.WAS_RELEASED, cb=btnA_wasReleased_event)
                                  BtnB.setCallback(type=BtnB.CB_TYPE.WAS_PRESSED, cb=btnB_wasPressed_event)
                                  BtnB.setCallback(type=BtnB.CB_TYPE.WAS_RELEASED, cb=btnB_wasReleased_event)
                                  BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_PRESSED, cb=btnPWR_wasPressed_event)
                                  BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_RELEASED, cb=btnPWR_wasReleased_event)
                                def loop():
                                  M5.update()
                                  time.sleep_ms(50)
                                if __name__ == '__main__':
                                  try:
                                    setup()
                                    while True:
                                      loop()
                                    try:
                                      print_error_msg(e)
                                    except ImportError:
                                All was working well in UiFlow 2.0.8 yesterday, please fix this so I can continue to use it.
                                • CAT the TechC
                                  CAT the Tech
                                  I also tried some other methods since, none of them had the desired effect:
                                  Method 2 - Pin buttons
                                  • This method works only with mode High (pull_low=False), with or without pull
                                  • It is incredibly slow to respond (about 1 second)
                                  import os, sys, io
                                  import M5
                                  from M5 import *
                                  import time
                                  Btn37 = None
                                  Btn39 = None
                                  Btn35 = None
                                  def btn37_wasPressed_event(state):
                                    global Btn37, Btn39, Btn35
                                    print('Pressed A')
                                  def btn39_wasPressed_event(state):
                                    print('Pressed B')
                                  def btn35_wasPressed_event(state):
                                  def btn35_wasReleased_event(state):
                                  def btn39_wasReleased_event(state):
                                    print('Released B')
                                  def btn37_wasReleased_event(state):
                                    print('Released A')
                                  def setup():
                                    print('hello M5')
                                    M5.begin()
                                    # Pin 37 == button A
                                    # Pin 39 == button B
                                    Btn37.setCallback(type=Btn37.CB_TYPE.WAS_PRESSED, cb=btn37_wasPressed_event)
                                    Btn37.setCallback(type=Btn37.CB_TYPE.WAS_RELEASED, cb=btn37_wasReleased_event)
                                    Btn39.setCallback(type=Btn39.CB_TYPE.WAS_PRESSED, cb=btn39_wasPressed_event)
                                    Btn39.setCallback(type=Btn39.CB_TYPE.WAS_RELEASED, cb=btn39_wasReleased_event)
                                    Btn35.setCallback(type=Btn35.CB_TYPE.WAS_PRESSED, cb=btn35_wasPressed_event)
                                    Btn35.setCallback(type=Btn35.CB_TYPE.WAS_RELEASED, cb=btn35_wasReleased_event)
                                  def loop():
                                    M5.update()
                                    Btn37.tick(None)
                                    Btn39.tick(None)
                                    Btn35.tick(None)
                                    time.sleep_ms(50)
                                    try:
                                      setup()
                                      while True:
                                        loop()
                                      try:
                                        print_error_msg(e)
                                      except ImportError:
                                  Method 3 - machine.Pin (IRQ)
                                  • It is fast, responsive
                                  • It cannot report accurately if the button was pressed or released if multiple events are queued one after the other
                                  import os, sys, io
                                  import M5
                                  from M5 import *
                                  import time
                                  from machine import Pin
                                  pin37 = None
                                  pin39 = None
                                  pin35 = None
                                  p = None
                                  # Describe this function...
                                  def button_callback(p):
                                    global pin37, pin39, pin35
                                    i = int(str(p)[4:-1])
                                    print(f"Button id: {i}, value: {p.value()}")
                                  def setup():
                                    print('hello M5')
                                    M5.begin()
                                    pin37 = Pin(37, mode=Pin.IN)
                                    pin39 = Pin(39, mode=Pin.IN)
                                    pin35 = Pin(35, mode=Pin.IN)
                                    pin37.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                                    pin39.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                                    pin35.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                                  def loop():
                                    M5.update()
                                    time.sleep_ms(50)
                                    try:
                                      setup()
                                      while True:
                                        loop()
                                      try:
                                        print_error_msg(e)
                                      except ImportError:
                                  Edit:
                                  Oh, right, I almost forgot.
                                  There is no such thing as the following in the machine.Pin method:
                                  p.irq().flags()
                                  I don't know if it is because of the micropython port you guys use or if it is the esp32-pico-v3-02's fault, but I think there is something missing there...
                                  • lbuqueL
                                    lbuque @CAT the Tech
                                    @CAT-the-Tech I tried running your code and found that it works well.
                                    CAT the TechC 1 Reply Last reply Reply Quote 0
                                    • CAT the TechC
                                      CAT the Tech @lbuque
                                      @lbuque Really?
                                      Which method did you use? (1, 2, or 3)
                                      What device are you using?
                                      • CAT the TechC
                                        CAT the Tech
                                        Since version 2.1.0, The Pin Buttons method (method 2) does not work AT ALL anymore
                                        • lbuqueL
                                          @CAT-the-Tech stickc_plus2
                                          • lbuqueL
                                            cores3 works fine
