Sorry, but new firmware breaks my projects... Again...
Not that I know of. I wish they'd have left it in Burner, it doesn't make too much sense to remove such recent firmware versions! If new firmware improves or fixes something, great, burn it! But this situation is a good example of why it's a good idea to leave past versions. It's not like 2.0.1 is ancient history?
Hello @aleksandar-atanasov
I cannot reproduce the issue you are describing. With UIFlow2.0.3 firmware on my M5AtomS3 I can scan the internal and external I2C bus just fine. Please see my example in the PlayZone called: M5AtomS3_I2C_Scan_UIFlow2.0.3
Do you get an error or just an empty list when you try to scan the I2C bus?
@brianr said in Sorry, but new firmware breaks my projects... Again...:
U032
I have same problem with GPS U032 and StickC Plus under UIFlow 2.03, not working...
Hello @flex
sorry, but I cannot reproduce the issue you are reporting. Running UIFlow2.0.3 firmware on my M5StickCPlus with a GPS unit works just fine. Please check PlayZone M5StickCPlus_GPS_unit_UIFlow2.0.3 example.
What exactly doesn't work for you? Do you get an error message in the log?
Hello @felmue
I have a program which works and start by:
Begin Initialization True
Init built-in hardware at beginning
Init BLE Uart client
....when I add "Init gps_0" before of after "Init BLE Uart client", it crashes
I tried on your program which works on my StickC Plus and GPS under UIFlow 2.03. When I just add "Init BLE Uart client" before or after "Init gps_0", it crashes also.
All my programs with BLE Server and BLE Client work fine and I can exchange data between 2 StickC Plus.
Pascal
Hello @flex
I can confirm that using init gps block with init BLE uart client block results in a crash. Tested with M5StickCPlus UIFlow2.0.4 firmware.
Note: when I add a 5 second delay in between the two init block I do not see a crash. However I did not confirm whether GPS or BLE still works.
Hello Felix,
thanks for confirmation.
Do you think that reason can be an incorrect memory management in lib gps or lib bleuart or lib M5?
To whom should be addressed that problem in M5Stack dev. team?
Pascal
I have contacted support, and they offered 2.0.4--hotfix to test, but neither that, nor 2.0.4, resolves this issue. They should be able to easily recreate this problem on their end, but I'm happy to keep testing for them.
Problem easily seen by burning new firmware from Burner, then create a new UIFlow2 project, and just add the M5Stack GPS to Unit, and hit Run. Errors. Take the "Init gps_0" out of the setup block and hit Run, and it loads the expected black screen. Add it back in, it errors...
Again asked for 2.0.1, even just temporarily, as a testing control to ensure that there is a firmware this worked with. We'll see...
Hello @BrianR
that is not what I am seeing. With M5Dial UIFlow firmware v2.0.4--hotfix my GPS example in the Project Zone runs just fine. M5Dial_GPS_Unit_UIFlow2.0.2
Edit: Just double-checked:
- Erase, burn UIFlow2.0.3, new project, add GPS unit, run -> error
- Erase, burn UIFlow2.0.4--hotfix, new project, add GPS unit, run -> no error
@felmue , I just spent a bit of time struggling to get any firmware to load onto either Dial that I have, but I finally got the --hotfix firmware loaded, and I can confirm that the GPS now works again!
Thank you M5Stack for taking the time to resolve!
