    C++ syntax question - Defining an object in a class that requires arguments?
    arduino
    2.1k
    • LukeSL
      LukeS
      I need some help with how to properly define an object in a class as a public object of the class for objects that require arguments. I would like to hardcode the arguments. For example I want to make the second UART port in a class and hardcode the UART to 2.
      .h file for class
      #ifndef TestClass_h
      #define TestClass_h
      #include "Arduino.h"
      #include <M5Unified.h>
      class TestClass {
        public:
          //-- Define RS458 to UART to UART2, HardwareSerial needs a UART number passed to it --
          //What I have tried, I would like to hardcode the UART number to 2. How do I do this?????
          HardwareSerial SerialRS485; // 1 - Does not compile, I need something in the .cpp file to make this work
          HardwareSerial SerialRS485(uint8_t _uart); // 2 - Can get this to compile but then does not compile if I use a uncomment the test funciton
          HardwareSerial SerialRS485(uint8_t 2); // 3 - Does not compile
          //constructor
          TestClass();
          //Functions - Main
          void testFunction();
        private:
          uint16_t _private1 = 0;
      #endif
      .cpp file for class
      #include "TestClass.h"
      //Constructor def
      TestClass::TestClass() {
      void TestClass::testFunction() {
          Serial.println("USB Serial Port");
          SerialRS485.println("RS485 Serial Port");
      main ino file
      #include <M5Unified.h> //For M5Stack ESP Hardware
      //Create test class
      TestClass TestObject;
      void setup(void)
        auto cfg = M5.config();  //M5 Unified config
        M5.begin(cfg);
        delay(500);
      void loop(void)
        M5.update(); //Update button state
        TestObject.testFunction();
        delay(1000);
      • P
        pstoehr @LukeS
        @lukes said in C++ syntax question - Defining an object in a class that requires arguments?:
        HardwareSerial
        Maybe this solves your problem ...
        class StaticClass {
        private:
            int myContent;
        public:
            StaticClass(int v){myContent = v;}
            void printout(){printf("%d\n",myContent);}
        class TestClass {
        public:
            //StaticClass myClass = StaticClass(42);    // With C11
            StaticClass myClass;
            TestClass() : myClass(42)
            void doit()
                myClass.printout();
        int main(void)
            TestClass tc;
            tc.doit();
