    UiFlow 2.0
    73
    186
    381.4k
    • J
      jdbaluch
      Is something wrong with UIFlow2 website right now? I cannot get my CoreS3 or my Atom S3 to utilize any of my sensors. Theyr'e all saying "Unit not defined" in the console as soon as I add any of them to a project.
      • J
        jazztunes @jdbaluch
        @jdbaluch I had the same problem with uiFlow2 + AtomS3. Check the code window and see if any imports are missing, particularly the unit import. Should be something like:
        import os, sys, io
        import M5
        from M5 import *
        from hardware import *
        from unit import *
        On mine, the unit import was missing. I tried
        • Switch to various different units
        • Fresh the website completely (F5, clear cookies, close tabs etc.).
        • Re-flash the unit with m5burner
        Somewhere in there, the unit import line decided to show up and then everything started working. ¯\(ツ)/¯
          sgu @IAMLIUBO
          @iamliubo
          6 Months later. Just flashed the Core S3 with the newest UiFlow 2.0 Alpha and still the modules are not integrated!
          Do you really want to sell the Core S3 ? without complete software support, the use cases for the Core S3 is very, very limited.
          • C
            codeblue
            is the UIFlow2.0 desktop edition available now?
            • L
              li0than
              wlan config misses reading of essid. Could you add this?
              Also would be very cool to have a way, where Block editor keeps working when only minor changes were made to the code.
              (when adjusting one variable cuz its not yet available, it would be awesome, if I could still keep using the block editor)
                Hello @li0than
                you could use the Execute mpy code block for stuff that is not (yet) available.
                • K
                  kapipema @IAMLIUBO
                  @iamliubo , When using a m5 dial it would be really nice to center text in a label in an easy fashion.
                  • T
                    tomspost
                    I am building a distributed smart control system for my sail boat using 6 m5Dials one in each cabin. They show all important boat data such as depth and wind speed and heading from an MQTT server running on a raspberry pi the also show alerts and allow control of local lighting.
                    I am having a lot of problems with UI Flow 2.
                    All I have working so far is lighting with dimming using the dial and night lighting (RED lights) working.
                    I need to get RFID working to login crew/family members so the m5Dials alerts them to their watches - I get an error when I put in any RFID blocks except "RFI init built in" I have an "if" in my main loop that calls a function if a new card or RFID phone is detected the function currently only reads the card ID converts it to a string and shows it on a label
                    My other problem is connecting into the MTTQ server this currently always hangs the device and I need to power cycle it to get any responses
                    I have MQTT code working on my m5 coreInk in uiFlow 1 which I am using for remote anchor control
                    I have plans to open source the project and I think it will be very useful for other sailers
                    I also want to do some YouTube system build videos but they will only currently show it not working!
                    I think I am expecting too much from alpha software.
                    Any suggestions or advice are welcome.
                    • D
                      daojah
                      I've installed UiIflow via m5 burner and after that my card computer don't starting at all, only red light on esp32. And I can't install any other soft
                        Uiflow is not for the S3 generation of which the card computer is based on, you need UIFLOW2 (please read the information printed in M5Burner first)
                        UIFLow2 does work on the Card computer but the current version is only for the StampS3, the card computer isn't yet configured.
                        • robskiR
                          robski @tomspost
                          @tomspost said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                          re:MQTT for me so far only mqtt config as "execute code" is working while using Uiflow2 - built in mqtt blocks didn't work - im connecting to HiveMQTT btw,
                          re:rfid when I had test M5Dial project installed then i could detect/read any of my rfid tokens but when I've tried to use built in blocks for rfid in Uiflow2 had no success really - I need to try harder
                            Hello @m5stack
                            UIFlow2.0.1 - M5 Cardputer : when I add Init keyboard and When keyboard was pressed blocks I get the following Python code:
                            def kb_pressed_event(kb):
                              global kb
                              pass
                            def setup():
                              global kb
                              kb.set_callback(kb_pressed_event)
                              M5.begin()
                              kb = MatrixKeyboard()
                            Unfortunately kb.set_callback(kb_pressed_event) is placed before kb = MatrixKeyboard(). E.g. before kb is defined. Resulting in AttributeError: NoneType object has not attribute set_callback.
                            Also in the callback function global kb is added which results in the following SyntaxError: identifier redefined as global.
                            BTW: running code:
                              pass
                            def setup():
                              global kb
                              M5.begin()
                            Please fix.
                              Hello @m5stack
                              thank you for fixing the first part.
                              However the second part is still wrong. Below code created by the When keyboard was pressed block:
                                global kb
                                pass
                              still returns a SyntaxError: identifier redefined as global.
                              Please fix this too.
                              • W
                                Waittherack
                                It seems like I can't download my programs anymore, neither in Wifi nor with the USB-C cable. I have a M5Stack Core2. This is what i get both ways : 0_1707839419278_644aa359-ea71-4ef4-a3e3-4ea80718fc6f-image.png 0_1707839440797_7063265d-eb2f-4c59-9f4d-f0b3d6ef1009-image.png
                                • Q
                                  Quakernate
                                  Hi All.
                                  New here and quite confused. Got the stickCplus2. Love the device, but writing/blocking some code is a pain in the a.. atm.
                                  Can't seem to recreate the experiment in the docs (https://docs.m5stack.com/en/quick_start/m5stickc_plus2/uiflow); turning on (one of) the LED(s)? In the docs it's blocked with the PIN blocks. Why are those not in the 'built-in hardware' section? The LED's are built-in, right? But also the exact same compilation as in the example does not turn on a LED when run.
                                  Then in the built-in section you can choose RGB, which definetely is not built-in?
                                  Some schematic overview of what button/led is which in the code language would be nice. (Just a picture of the device having the code-name next to where it would be placed in the device. Understand what I'm trying to say?
                                  Is UIflow1 still more stable? Must say, UI2 looks very good. But that's about it for now it seems.
                                  Sorry for such a long comment already. Got a lot more questions, but I will come back with those later. Still a noob in the esp32 anyway, so I'll keep trying to find out stuff by myself as well.
                                  Cheers!
                                  • Q
                                    Quakernate
                                    Hi, Quakernate again.
                                    Seems like there just isn't a LED available in UIFlow2.0. (thought it would maybe be named different) Was toying around in the UIFlow1 and there I was able to turn on the LED nd stuff way easier. (especially since there is a LED block at all)
                                    Will code some in UIF1.13 until UIF2.0 is suitable (enough) for play.
                                    If usefull I'm willing to keep fooling around in 2.0 as well just to list more bugs.
                                      There is an RGB LED available in UIFLow but you need to use the Micropython code to call it.
                                      • B
                                        BritOnTour
                                        Is there any option to import or convert a UiFlow 1 Blockly project to UiFlow 2?
                                        1 Reply Last reply Reply Quote 4
                                        • teastainT
                                          teastain @ajb2k3
                                          @ajb2k3 I wonder what the difference is between UIFlow ver 1 and ver 2?
                                          Can sketches be ported over from ver to ver 2, but not vice/versa?
                                          • dissyD
                                            dissy
                                            Bug fix request
                                            UIFlow2 "http" block is completely non-functional, failing to load the 'requests' library. There is a typo with an errant 'u' that should not be there.
                                            ImportError: no module named 'urequests'
