    M5Stack ENV III
    ESP - IDF
    4.9k
    • B
      bl0__
      I am working on a school project and we have to use the ENVIII sensor. There is very little documentation about this device or at least how to use it with the M5Stack, I have only found a GitHub repository with example Arduino codes.
      I have tried out the ENVIII example code, which does not quite work. After a bit of fixing, I managed to get the Temp, Humidity and Pressure printed on the LCD but it just shows 0 for each. I assume they are stuck to their initial value and the sht30 functions are not working.
      If that can help, I am using the port A (Red).
      Have a good day
      • C
        csierra67
        The sensor works right away under UI Flow. I don't have any experience with it under C++
        • B
          bl0__
          Thank you very much for your reply! I will look into UI Flow.
          • teastainT
            teastain @bl0__
