    Can't subscribe to MQTT topic
    UiFlow 2.0
    6
    15
    13.5k
      Well that explains it. MQTT in UIFlow is a bit broken as UIFlow2 is for testing only
      • O
        Oskars @ajb2k3
        @ajb2k3In that case, is there an option to use UIFlow with S3 while UIFlow2 is "for testing only"? I did not see any warnings saying "things will not work" while buying it. Is there any timeframe when the already enabled functionality might work? I'm currently not asking about new features or support for more hardware, just for the things that already are available in UI.
          Hello @Oskars
          FWIW: global variable mqtt_client is used in setup to subscribe before it is initialized. Unfortunately in UIFlow2 the Python tab is non functional yet, so the sequence cannot be fixed on the fly.
          • O
            Oskars @felmue
            @felmue Thank You, after I changed the code via Thonny and moved mqtt_client.subscribe after initialization the error disappeared. However the device still does not react to MQTT topics it has subscribed. So the bug is not only in UIFlow2 (incorrectly placed subscribe call) but also in MQTT library or firmware?
            • A
              alwa123
              Any news here?
                Hello guys
                just tested again. MQTT subscribe is still broken for me in alpha 14. Please fix.
                U 1 Reply Last reply Reply Quote 1
                • U
                  UKTechguy @felmue
                  @felmue Somewhat annoying that so much seems to be broken at the moment. We have no buttons and I cannot work out how to do anything with the microsd card. Would like to play a wav alarm file when specific MQTT message is received. Neither seems possible yet.
                    Its is still alpha so not the finale item and ma have code changed.
                    U 1 Reply Last reply Reply Quote 0
                    • U
                      UKTechguy @ajb2k3
                      @ajb2k3 It would be good if M5stack had some sort of chart or spreadsheet that stated what currently worked and what didn't. Also an eta for things coming etc. Compared with the number of M5stack youtube "how to" videos that appeared for previous "Core" products, the CoreS3 is suffering. Maybe I got on the Core2/Fire bandwagon after most teething troubles were fixed and most features were no longer "Alpha"!
                      • O
                        Oskars
                        MQTT topic subscribe still seems to be not working in Alpha 16 - no error but no activity on message receiving either. Anyone else has the same issue?
                        • lbuqueL
                          lbuque
                          @Oskars
                          version: Alpha-17
                          import os, sys, io
                          import M5
                          from M5 import *
                          from umqtt import *
                          label0 = None
                          label2 = None
                          label1 = None
                          label3 = None
                          mqtt_client = None
                          def mqtt_testtopic_event(data):
                            global label0, label2, label1, label3, mqtt_client
                            label0.setText(str(((str('Topic:') + str((data[0]))))))
                            label1.setText(str(((data[1]).decode())))
                          def mqtt_testtopic1_event(data):
                            label2.setText(str(((str('Topic:') + str((data[0]))))))
                            label3.setText(str(((data[1]).decode())))
                          def setup():
                            M5.begin()
                            label0 = Widgets.Label("Text", 4, 3, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                            label2 = Widgets.Label("Text", 4, 55, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                            label1 = Widgets.Label("Text", 4, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                            label3 = Widgets.Label("Text", 3, 81, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                            mqtt_client = MQTTClient('umqtt_client', '192.168.2.50', port=1883, user='m5stack', password='m5stack', keepalive=0)
                            mqtt_client.connect(clean_session=True)
                            mqtt_client.subscribe('testtopic', mqtt_testtopic_event, qos=0)
                            mqtt_client.subscribe('testtopic1', mqtt_testtopic1_event, qos=0)
                            label0.setFont(Widgets.FONTS.DejaVu12)
                            label1.setFont(Widgets.FONTS.DejaVu12)
                            label2.setFont(Widgets.FONTS.DejaVu12)
                            label3.setFont(Widgets.FONTS.DejaVu12)
                          def loop():
                            M5.update()
                            mqtt_client.wait_msg()
                          if __name__ == '__main__':
                            try:
                              setup()
                              while True:
                                loop()
                              try:
                                print_error_msg(e)
                              except ImportError:
                          test_mqtt.m5f2
                          {"version":"V2.0","type":"atoms3","components":[{"name":"screen","type":"screen","layer":0,"screenId":"","screenName":"","id":"__atoms3_screen","createTime":1681463262614,"x":0,"y":0,"width":280,"height":280,"backgroundColor":"#000","size":0},{"name":"label0","type":"label","layer":1,"screenId":"builtin","screenName":"","id":"v^k&_0&lzY#a-pVu","createTime":1681787932237,"x":4,"y":3,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0},{"name":"label1","type":"label","layer":2,"screenId":"builtin","screenName":"","id":"lg-u6bmP&KAb-BFg","createTime":1681787940036,"x":4,"y":29,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0},{"name":"label2","type":"label","layer":1,"screenId":"builtin","screenName":"","id":"m+Am3fMqYyQ$+VEm","createTime":1681788301006,"x":4,"y":55,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0,"width":37,"height":20},{"name":"label3","type":"label","layer":2,"screenId":"builtin","screenName":"","id":"fj^rW#mTo@K0dL5r","createTime":1681788303358,"x":3,"y":81,"color":"#ffffff","backgroundColor":"#222222","text":"Text","engine":"gfx","font":"Widgets.FONTS.DejaVu18","rotation":0,"width":37,"height":20}],"resources":[{"software":["mqtt"]}],"units":[],"hats":[],"i2cs":[],"blockly":"<block type=\"basic_on_loop\" id=\"loop_block\" deletable=\"false\" x=\"490\" y=\"70\"><mutation isUpdate=\"true\"></mutation><field name=\"UPDATEOP\">true</field><statement name=\"FUNC\"><block type=\"system_m5_update\" id=\"system_m5_update\"><next><block type=\"mqtt_wait_msg\" id=\"T1rVj/Q%g){|@a=eic@f\"></block></next></block></statement></block><block type=\"basic_on_setup\" id=\"setup_block\" deletable=\"false\" x=\"130\" y=\"110\"><mutation isBegin=\"true\"></mutation><field name=\"UPDATEOP\">true</field><statement name=\"FUNC\"><block type=\"system_m5_begin\" id=\"system_m5_begin\"><next><block type=\"mqtt_set_client\" id=\"g+(|o=#m4jpn7OLPkw)J\"><value name=\"ID\"><shadow type=\"text\" id=\"?[M!b8*f#bx*SpMXH!!5\"><field name=\"TEXT\">umqtt_client</field></shadow></value><value name=\"SERVER\"><shadow type=\"text\" id=\"oNzSR(TF-,inxj~YS2}#\"><field name=\"TEXT\">192.168.2.76</field></shadow></value><value name=\"PORT\"><shadow type=\"math_number\" id=\"e~GXuZ!~qfASA;IYe3f=\"><mutation max=\"Infinity\" min=\"-Infinity\" precision=\"0\"></mutation><field name=\"NUM\">1883</field></shadow></value><value name=\"USER\"><shadow type=\"text\" id=\"3PbUi]|zTswyRzP*h=Zm\"><field name=\"TEXT\">m5stack</field></shadow></value><value name=\"PASSWORD\"><shadow type=\"text\" id=\"d.(iU%~um%@j5=N8C!9:\"><field name=\"TEXT\">m5stack</field></shadow></value><value name=\"KEEPALIVE\"><shadow type=\"math_slider\" id=\"4lCv3Yqkt^hJHwEHH,R)\"><mutation max=\"65535\" min=\"0\" step=\"1\" precision=\"1\"></mutation><field name=\"NUM\">0</field></shadow></value><next><block type=\"mqtt_connect\" id=\"N$GCr?UqrYp~!@[yZfZ~\"><field name=\"CLEAN\">True</field><next><block type=\"label_set_font\" id=\"sBjX6,JwP2hIWbkZU]#L\"><field name=\"NAME\">label0</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"l{(uGTFfhsb)s(6iS/hU\"><field name=\"NAME\">label1</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"Rn6r~[cLiSQf+]nM8sTq\"><field name=\"NAME\">label2</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field><next><block type=\"label_set_font\" id=\"oaK+AUCEaQtl@kR^|jP;\"><field name=\"NAME\">label3</field><field name=\"FONT\">Widgets.FONTS.DejaVu12</field></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block><block type=\"mqtt_subscribe\" id=\"w7Ov@_:I,|/99:[91gQ+\" x=\"90\" y=\"570\"><value name=\"MSG\"><shadow type=\"text\" id=\"5+0D;yAI;M9Kab.KdV([\"><field name=\"TEXT\">testtopic</field></shadow></value><statement name=\"FUNC\"><block type=\"label_set_text\" id=\"qN{uc|lEU4,^0u_YYo@7\"><field name=\"NAME\">label0</field><value name=\"TEXT\"><shadow type=\"text\" id=\"5~k^hoGX6L}naX9o!pt=\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_add_str\" id=\"tAsN]8zdz!{wa]J5fQRj\"><value name=\"VALUE1\"><shadow type=\"text\" id=\"NTGIBKM?0;M)9Q$?/F/E\"><field name=\"TEXT\">Topic:</field></shadow></value><value name=\"VALUE2\"><block type=\"mqtt_get_topic\" id=\"O)j9sIdBDlw?k(Y4#E{]\"></block></value></block></value><next><block type=\"label_set_text\" id=\"AIj|L5*V}(Na=i~]!Wr{\"><field name=\"NAME\">label1</field><value name=\"TEXT\"><shadow type=\"text\" id=\"9gNvISVfV@]35[tz`S6-\" disabled=\"true\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_decode_str\" id=\"}[Ilzb9o=Qd12AOz*Q/k\"><value name=\"VALUE\"><block type=\"mqtt_get_msg\" id=\"p48aW7MN4QcC/]H_RqLv\"></block></value></block></value></block></next></block></statement></block><block type=\"mqtt_subscribe\" id=\":g;Bc#f6bCJv3D=P,C24\" x=\"690\" y=\"550\"><value name=\"MSG\"><shadow type=\"text\" id=\"p!BP(rRWfzb8%w2;)|Z/\"><field name=\"TEXT\">testtopic1</field></shadow></value><statement name=\"FUNC\"><block type=\"label_set_text\" id=\"+{@FB5tyv:a,[(0)S^?^\"><field name=\"NAME\">label2</field><value name=\"TEXT\"><shadow type=\"text\" id=\"5~k^hoGX6L}naX9o!pt=\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_add_str\" id=\"MOXaUlFRx59,!q}DPD;6\"><value name=\"VALUE1\"><shadow type=\"text\" id=\"ABnF09VK)vlEkGQ|B9P*\"><field name=\"TEXT\">Topic:</field></shadow></value><value name=\"VALUE2\"><block type=\"mqtt_get_topic\" id=\"3w2H7IRX7ZEIXgo$ZPFE\"></block></value></block></value><next><block type=\"label_set_text\" id=\"sAd`+qhCgZXd{Kt,+h$r\"><field name=\"NAME\">label3</field><value name=\"TEXT\"><shadow type=\"text\" id=\"9gNvISVfV@]35[tz`S6-\" disabled=\"true\"><field name=\"TEXT\">Label</field></shadow><block type=\"text_decode_str\" id=\"(3lEfMbcJYt7tw_fl=%3\"><value name=\"VALUE\"><block type=\"mqtt_get_msg\" id=\"YAAO(q1I]VjM1vGhYh2R\"></block></value></block></value></block></next></block></statement></block>","screen":[{"simulationName":"Built-in","type":"builtin","width":128,"height":128,"scale":1.3,"screenName":"","blockId":"","id":"builtin","createTime":1681463262611}]}
                          O 1 Reply Last reply Reply Quote 2
                          • O
                            Oskars @lbuque
                            @lbuque Thanks a million to You, I finally got the code working! Looks like the thing I was missing was to use "MQTT apply for messaging" block in the loop. And changing the default 0 keepalive value (after some searching I found it caused problems with my Mosquitto broker).
