[Solved]Error compiling ESP32 Camera Demo
I bought a M5Stack ESP32 Camera. I am happy, it worked out of the box with the preloaded firmware. I wanted to change from AP to STA mode. While compiling the demo I get the following error. Can any one help.
CC build/main/app_main.o
/home/partha/esp32-cam-demo/main/app_main.c:56:34: error: unknown type name 'http_context_t'
static void handle_grayscale_pgm(http_context_t http_ctx, void* ctx);
Hi Vikaci would you mind showing us the code you used and which IDE you used to program the camera, the more information we have the better we can help you
@lukasmaximus Tried the sample code given in https://github.com/m5stack/esp32-cam-demo as it is. Only change I did was from AP to STA in
make menuconfig. -
Error has it.
IDF version 8b885fb
m5stack/esp32-cam-demo 0f8a432 -
@mschu7 should I change to a earlier version of esp-idf.
@lukasmaximus
@mschu7
Thanks. It works now. Taking a clue from another post, I did,
git checkout 3b92e85
on esp-idfThen, it compiles without any error. I am able to flash and make it work as a STA.
because ,you don't have the esp32-http-server component and in the file .gitmodules components path name is wrong. so we can goto the directory ./component , and run "git clone https://github.com/igrr/esp32-http-server.git" to download this component , and you will fix it.
@zhouyangwen Thanks. This is works. Now i am abo
