    Arducam (arduino) Can't find OV2640 module!
    PRODUCTS
    9.3k
      @m5stack Have you guys got any idea how to get the arducam esp32 examples working on the M5Camera (2nd version)?
        // ArduCAM Mini demo (C)2017 Lee
        // Web: http://www.ArduCAM.com
        // This program is a demo of how to use most of the functions
        // of the library with ArduCAM ESP32 2MP/5MP camera.
        // This demo was made for ArduCAM ESP32 2MP/5MP Camera.
        // It can take photo and send to the Web.
        // It can take photo continuously as video streaming and send to the Web.
        // The demo sketch will do the following tasks:
        // 1. Set the camera to JPEG output mode.
        // 2. if server receives "GET /capture",it can take photo and send to the Web.
        // 3.if server receives "GET /stream",it can take photo continuously as video
        //streaming and send to the Web.
        // This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM ESP32 2MP/5MP camera
        // and use Arduino IDE 1.8.1 compiler or above
        #include <WiFi.h>
        #include <Wire.h>
        #include <ESP32WebServer.h>
        #include <ArduCAM.h>
        #include <SPI.h>
        #include "memorysaver.h"
        #if !(defined ESP32 )
        #error Please select the ArduCAM ESP32 UNO board in the Tools/Board
        #endif
        //This demo can only work on OV2640_MINI_2MP or ARDUCAM_SHIELD_V2 platform.
        #if !(defined (OV2640_MINI_2MP)||defined (OV5640_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP_PLUS) \
            || defined (OV5642_MINI_5MP) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) \
            ||(defined (ARDUCAM_SHIELD_V2) && (defined (OV2640_CAM) || defined (OV5640_CAM) || defined (OV5642_CAM))))
        #error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
        #endif
        // set GPIO17 as the slave select :
        const int CS = 17;
        const int CAM_POWER_ON = D10;
        #if defined (OV2640_MINI_2MP) || defined (OV2640_CAM)
          ArduCAM myCAM(OV2640, CS);
        #elif defined (OV5640_MINI_5MP_PLUS) || defined (OV5640_CAM)
          ArduCAM myCAM(OV5640, CS);
        #elif defined (OV5642_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) ||(defined (OV5642_CAM))
          ArduCAM myCAM(OV5642, CS);
        #endif
        //you can change the value of wifiType to select Station or AP mode.
        //Default is AP mode.
        int wifiType = 1; // 0:Station  1:AP
        //AP mode configuration
        //Default is arducam_esp8266.If you want,you can change the AP_aaid  to your favorite name
        const char *AP_ssid = "M5Cam";
        //Default is no password.If you want to set password,put your password here
        const char *AP_password = NULL;
        //Station mode you should put your ssid and password
        const char *ssid = "SSID"; // Put your SSID here
        const char *password = "PASSWORD"; // Put your PASSWORD here
        static const size_t bufferSize = 2048;
        static uint8_t buffer[bufferSize] = {0xFF};
        uint8_t temp = 0, temp_last = 0;
        int i = 0;
        bool is_header = false;
        ESP32WebServer server(80);
        void start_capture(){
          myCAM.clear_fifo_flag();
          myCAM.start_capture();
        void camCapture(ArduCAM myCAM){
        WiFiClient client = server.client();
        uint32_t len  = myCAM.read_fifo_length();
        if (len >= MAX_FIFO_SIZE) //8M
          Serial.println(F("Over size."));
        if (len == 0 ) //0 kb
          Serial.println(F("Size is 0."));
        myCAM.CS_LOW();
        myCAM.set_fifo_burst();
        if (!client.connected()) return;
        String response = "HTTP/1.1 200 OK\r\n";
        response += "Content-Type: image/jpeg\r\n";
        response += "Content-len: " + String(len) + "\r\n\r\n";
        server.sendContent(response);
        i = 0;
        while ( len-- )
        temp_last = temp;
        temp =  SPI.transfer(0x00);
        //Read JPEG data from FIFO
        if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
        buffer[i++] = temp;  //save the last  0XD9
        //Write the remain bytes in the buffer
        if (!client.connected()) break;
        client.write(&buffer[0], i);
        is_header = false;
        i = 0;
        myCAM.CS_HIGH();
        break;
        if (is_header == true)
        //Write image data to buffer if not full
        if (i < bufferSize)
        buffer[i++] = temp;
        else
        //Write bufferSize bytes image data to file
        client.write(&buffer[0], bufferSize);
        i = 0;
        buffer[i++] = temp;
        else if ((temp == 0xD8) & (temp_last == 0xFF))
        is_header = true;
        buffer[i++] = temp_last;
        buffer[i++] = temp;
        void serverCapture(){
          delay(1000);
        start_capture();
        Serial.println(F("CAM Capturing"));
        int total_time = 0;
        total_time = millis();
        while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
        total_time = millis() - total_time;
        Serial.print(F("capture total_time used (in miliseconds):"));
        Serial.println(total_time, DEC);
        total_time = 0;
        Serial.println(F("CAM Capture Done."));
        camCapture(myCAM);
        Serial.print(F("send total_time used (in miliseconds):"));
        Serial.println(F("CAM send Done."));
        void serverStream(){
        response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
        while (1){
        start_capture();
        size_t len = myCAM.read_fifo_length();
        continue;
        continue;
        myCAM.CS_LOW();
        response = "--frame\r\n";
        response += "Content-Type: image/jpeg\r\n\r\n";
        while ( len-- )
        temp_last = temp;
        myCAM.CS_HIGH();;
        is_header = false;
        i = 0;
        if (i < bufferSize)
        buffer[i++] = temp;
        else
        myCAM.CS_HIGH();
        i = 0;
        buffer[i++] = temp;
        myCAM.CS_LOW();
        is_header = true;
        buffer[i++] = temp;
        void handleNotFound(){
        String message = "Server is running!\n\n";
        message += "URI: ";
        message += server.uri();
        message += "\nMethod: ";
        message += (server.method() == HTTP_GET)?"GET":"POST";
        message += "\nArguments: ";
        message += server.args();
        message += "\n";
        server.send(200, "text/plain", message);
        Serial.println(message);
        if (server.hasArg("ql")){
        int ql = server.arg("ql").toInt();
        myCAM.OV2640_set_JPEG_size(ql);
        myCAM.OV5640_set_JPEG_size(ql);
        #elif defined (OV5642_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) ||(defined (OV5642_CAM))
        myCAM.OV5642_set_JPEG_size(ql);
        #endif
        Serial.println("QL change to: " + server.arg("ql"));
        uint8_t vid, pid;
        uint8_t temp;
          //set the CS as an output:
          pinMode(CS,OUTPUT);
          pinMode(CAM_POWER_ON , OUTPUT);
          digitalWrite(CAM_POWER_ON, HIGH);
        #if defined(__SAM3X8E__)
        Wire1.begin();
        #else
        Wire.begin();
        #endif
        Serial.begin(115200);
        Serial.println(F("ArduCAM Start!"));
        // initialize SPI:
        SPI.begin();
        SPI.setFrequency(4000000); //4MHz
        //Check if the ArduCAM SPI bus is OK
        myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
        temp = myCAM.read_reg(ARDUCHIP_TEST1);
        if (temp != 0x55){
        Serial.println(F("SPI1 interface Error!"));
        while(1);
        if (temp != 0x55){
        while(1);
        //Check if the camera module type is OV2640
        myCAM.wrSensorReg8_8(0xff, 0x01);
        myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
        myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
        if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 )))
        Serial.println(F("Can't find OV2640 module!"));
        else
        Serial.println(F("OV2640 detected."));
        Serial.print ("vid = ");
        Serial.println (vid);
        Serial.print ("pid = ");
        Serial.println (pid);
        //Check if the camera module type is OV5640
        myCAM.wrSensorReg16_8(0xff, 0x01);
        myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &vid);
        myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &pid);
        if((vid != 0x56) || (pid != 0x40))
        Serial.println(F("Can't find OV5640 module!"));
        else
        Serial.println(F("OV5640 detected."));
        //Check if the camera module type is OV5642
        myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
        myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
        if((vid != 0x56) || (pid != 0x42)){
        Serial.println(F("Can't find OV5642 module!"));
        else
        Serial.println(F("OV5642 detected."));
        #endif
        //Change to JPEG capture mode and initialize the OV2640 module
        myCAM.set_format(JPEG);
        myCAM.InitCAM();
        myCAM.OV2640_set_JPEG_size(OV2640_320x240);
        myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
        myCAM.OV5640_set_JPEG_size(OV5640_320x240);
        myCAM.OV5640_set_JPEG_size(OV5642_320x240);
        #endif
        if (wifiType == 0){
        if(!strcmp(ssid,"SSID")){
        Serial.println(F("Please set your SSID"));
        while(1);
        if(!strcmp(password,"PASSWORD")){
        Serial.println(F("Please set your PASSWORD"));
        while(1);
        // Connect to WiFi network
        Serial.println();
        Serial.println();
        Serial.print(F("Connecting to "));
        Serial.println(ssid);
        WiFi.mode(WIFI_STA);
        WiFi.begin(ssid, password);
        delay(500);
        Serial.print(F("."));
        Serial.println(F("WiFi connected"));
        Serial.println("");
        Serial.println(WiFi.localIP());
        }else if (wifiType == 1){
        Serial.println();
        Serial.println();
        Serial.print(F("Share AP: "));
        Serial.println(AP_ssid);
        Serial.print(F("The password is: "));
        Serial.println(AP_password);
        WiFi.mode(WIFI_AP);
        WiFi.softAP(AP_ssid, AP_password);
        Serial.println("");
        Serial.println(WiFi.softAPIP());
        // Start the server
        server.on("/capture", HTTP_GET, serverCapture);
        server.on("/stream", HTTP_GET, serverStream);
        server.onNotFound(handleNotFound);
        server.begin();
        Serial.println(F("Server started"));
            server.handleClient();
        m5-docsM 3 Replies Last reply Reply Quote 0
        • m5-docsM
          m5-docs @ajb2k3
          Hi, I have not tried ArduCAM. But once I'm free, I'll try that.
          • m5-docsM
            m5-docs @ajb2k3
            • m5-docsM
              m5-docs @ajb2k3
              Here's the pinmap about camera supplied by m5stack.
              https://github.com/m5stack/M5-Schematic/blob/master/Units/m5camera/hardware_diff_with_ESP32CAM_M5Camera.md
                @watson 在 Arducam (arduino) Can't find OV2640 module! 中说:
                That doesn't tie up because the arducams arduino_pin.h has D2 as I/O12
                and slave select as I/O17
