    need your advice for data transfer from a CORE2 to an ATOM display !
    UIFlow
    3.7k
    • ArnoA
      Arno
      What is the simplest and fastest communication solution (Modbus, UART, CAN,...) to communicate around 20 variables from a CORE2 to an ATOM DISPLAY? the two controllers will be in the same box at 10cm.
      Should the data be sent as a list? do you have any examples in UIFLOW?
      • teastainT
        teastain @Arno
        @arno The built-in SPI would provide the fastest frame rate but trickier to access the SPI on the Core2, second choice is the built-in I2C interface accessible by the standard Grove port on the left side.
        The Core2 is bereft of GPIO as a nod to WiFi BLE I2C ESP_NOW, etc, whereas the foundational Core Basic is better equipped with I/O options!!!
        I think M5Stack announced recently a GPIO base to convert the Core2.
        I have a Core2 running a simulated nixie-tube clock and two Core Basics.
        https://shop.m5stack.com/collections/m5stack-new-arrival/products/extension-port-module-for-core2?variant=43165402398977
        Extension Port Module for Core2
        SKU: M123 Regular price$6.95 Out Of Stock
        • ArnoA
          Arno
          Thanks Teastain
          I have the expansion module for CORE 2
          I am looking for advice on the mode of communication to use to transfer from CORE2 to the ATOM Display, and how to transmit around 20 digital variables?
