    Stange interaction between clock and temprature sensor setup
    esp32 c++ arduino
    6.0k
    • E
      EricR
      Hi and thanks for you're time
      I am a relative beginner to M5Stack and have made 2 test programs. One that displays weekday, date and time and one that use a Dallas 18B2D temperature sensor to display the room temperature. Both works interdependent.
      However a strange interaction between the two setups occur when I try to implement them both on the same time.
      If the sensor is connected to M5Stack during start up, then the internet setup won't connect, resulting in the weekday, date and time not working but the sensor value is displayed correctly.
      If the sensor is disconnected from M5Stack during start up, then the internet setup will connect and weekday, date and time displays... But the sensor will not setup correctly and the sensor value is not displayed correctly.
      I can't find the reason why the internet setup wont work when an analog input is connected to my M5Stack. Do you, masters of the M5Stack have any idea what could be the cause?
      ---------------------------------------------------- Copy of my code ---------------------------------------------------------------------------------
      #include <M5Stack.h>
      #include <WiFi.h>
      #include <GParser.h>
      #include <OneWire.h>
      #include <DallasTemperature.h>
      #include "time.h"
      // Set the name and password of the wifi to be connected.
      const char* ssid = "####WIFI#####";
      const char* password = "##Stuff##";
      // Setup for NTP server and GMT offset as well as if daylight savings
      const char* ntpServer = "se.pool.ntp.org"; // Set the connect NTP server.
      const long gmtOffset_sec = 3600;
      const int daylightOffset_sec = 3600;
      // Setup and declaration of therometer sensor
      #define ONE_WIRE_BUS 2 // Data wire is plugged into port 2 on the Arduino
      OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices
      DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
      DeviceAddress insideThermometer; // arrays to hold device address
      void printLocalTime() {
      struct tm timeinfo;
      if (!getLocalTime(&timeinfo)) { // Return 1 when the time is successfully obtained.
      M5.Lcd.println("Failed to obtain time. \nPlease restart");
      return;
      // Wright weekday
      M5.Lcd.setTextSize(5); // Set the font size.
      M5.Lcd.setCursor(40, 10); // Set cursor
      M5.Lcd.println(&timeinfo, "%A");
      // Wright date, month and year
      M5.Lcd.setTextSize(3);     // Set the font size.
      M5.Lcd.setCursor(10, 64);  // Set cursor
      M5.Lcd.println(&timeinfo, "%d %B %Y");
      // Wright time of day
      M5.Lcd.setCursor(40, 100);  // Set cursor
      M5.Lcd.println(&timeinfo, "%H:%M:%S");
      // function to print a device address
      void printAddress(DeviceAddress deviceAddress)
      for (uint8_t i = 0; i < 8; i++)
      if (deviceAddress[i] < 16) M5.Lcd.print("0");
      M5.Lcd.print(deviceAddress[i], HEX);
      // function to print the temperature for a device
      void printTemperature(DeviceAddress deviceAddress)
      M5.Lcd.setCursor(20, 170);
      M5.Lcd.print("Temp C: ");
      M5.Lcd.print(sensors.getTempC(deviceAddress));
      M5.begin(); // Init M5Core.
      M5.Power.begin(); // Init power
      M5.Lcd.setTextSize(2); // Set the font size to 2
      // Therometer setup information
      Serial.begin(9600);                   // start serial port
      M5.Lcd.print("Parasite power is: ");  // report parasite power requirements
      if (sensors.isParasitePowerMode()) M5.Lcd.print("ON");
      else M5.Lcd.print("OFF");;
      M5.Lcd.println();
      if (!sensors.getAddress(insideThermometer, 0)) M5.Lcd.println("Unable to find address for Device 0");
      M5.Lcd.print("Device 0 Address: ");// show the addresses we found on the bus
      printAddress(insideThermometer);
      M5.Lcd.println();
      sensors.setResolution(insideThermometer, 9);    // set the resolution to 9 bit
      M5.Lcd.print("Device 0 Resolution: ");
      M5.Lcd.print(sensors.getResolution(insideThermometer), DEC);
      M5.Lcd.println();
      // Internet comunication information
      M5.Lcd.printf("\nConnecting to %s", ssid);
      WiFi.begin(ssid, password);  // Connect wifi and return connection status.
      while (WiFi.status() !=
             WL_CONNECTED) {  // If the wifi connection fails.
          delay(500);         // delay 0.5s.
          M5.Lcd.print(".");
      M5.Lcd.println("\nCONNECTED!");
      configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);  // init and get the time.
      printLocalTime();
      WiFi.disconnect(true);  // Disconnect wifi.
      WiFi.mode(WIFI_OFF);    // Set the wifi mode to off.
      delay(20);
      // Clear all setup text
      M5.Lcd.clear();
      printLocalTime();
      sensors.requestTemperatures(); // Send the command to get temperatures
      printTemperature(insideThermometer);
        Hello @EricR
        your code runs fine (both time and temperature sensor together) for me.
        The only thing I've modified is increasing the timeout to 10 seconds for getting the time. (Default is 5 seconds.) E.g. getLocalTime(&timeinfo, 10000).
        How are you powering the temperature sensor? I don't use parasite power and feed it from the 3.3 V line.
        Have you tried to use a different GPIO for the temperature sensor?
        • E
          EricR @felmue
          Hi @felmue and thanks for the help. I changed GPIO and it works now. Strange as input port 2 worked when the temperature sensor were implemented separably.
          However I have spend enough time trying to make it work. So I will not conplain now that it is working.
          Thanks again
