    How to Generate a Beep?
    19 Posts 10 Posters 38.7k Views 4 Watching
      AgreeDK
      Just did a test, it will/can play a Beep om CORE2, just change Atom to CORE2 include, change the i2s pins and make one line a comment, the line not supported by CORE2.
      And yes, it is far to much code to get a Beep ;-)
        akaf24
        thank you for the reply. I think I'm stuck on pin assignment. So on the back of my core2, it says BCLK is 12, LRCK is 0 and DATA is 0. But the example code also has "CONFIG_I2S_DATA_IN_PIN" and "SPEAKER_I2S_NUMBER" but I am not sure what to assign these as.
          AgreeDK @akaf24
          @akaf24 DATA should be 2 not 0, you dont need to change the last two items.
          ( "CONFIG_I2S_DATA_IN_PIN" and "SPEAKER_I2S_NUMBER" )
            akaf24 @AgreeDK
            @agreedk thank you for reply. I keep getting a compile error. A beep isn't totally needed in my project so i'm just going to leave it out.
              Shift1313
              I haven't tried this but in the .h file there is something called Speaker.setBeep . That might just work.
              in the M5Stack.h file there is this.
              Speaker:
                  M5.Speaker.tone(uint32_t freq);
                  M5.Speaker.tone(freq, time);
                  M5.Speaker.beep();
                  M5.Speaker.setBeep(uint16_t frequency, uint16_t duration);
                  M5.Speaker.mute();
              And if you open up the example "FactoryTest" there is a section in the code that uses dacWrite to the speaker pin.
              void startupLogo() {
              static uint8_t brightness, pre_brightness;
              uint32_t length = strlen((char*)m5stack_startup_music);
              M5.Lcd.setBrightness(0);
              M5.Lcd.pushImage(0, 0, 320, 240, (uint16_t *)gImage_logoM5);
              for(int i=0; i<length; i++) {
              dacWrite(SPEAKER_PIN, m5stack_startup_music[i]>>2);
              delayMicroseconds(40);
              brightness = (i/157);
              if(pre_brightness != brightness) {
              pre_brightness = brightness;
              M5.Lcd.setBrightness(brightness);
              The startup_music.c is found on another tab when you open the example code.
              // SAMPLES: 40000,
              // BITSPERSAMPLE: 8,
              // CHANNELS: 1,
              // SAMPLERATE: 20000,
              // NORMALIZED: FALSE,
              const unsigned char m5stack_startup_music[] = {
              Lots of HEX here*
              • E Offline
                erich
                @AgreeDK Thanks a million for your solution, it does work perfectly with the Core2 !
                Just a shame there's no simple beep method in the core2 lib :(
                @Shift1313 as far as I understand, the .Speaker method you are referring to is not part of the M5Core lib, it is working with the Core but not with the Core2
                  in UIFlow you use this block to make a bleep
                  • E Offline
                    erich
                    @ajb2k3 Thanks for the tip. Unfortunately it is not that easy when not using UIFlow.
                    I am using VSCode + PIO with the Arduino framework
                    • O Offline
                      olliy78
                      I could not here any sound on my system by using the method described above by @AgreeDK. I figured out that you have to switch on the power supply for the integrated amplifier. This is controlled (like all other things needing power inside the Core2) by the APX192. To activate the Power supply use :
                      M5.Axp.SetSpkEnable(1);
                      • L Offline
                        LostInSpace
                        I too had this need with my Core 2 Stack, so I wrote a few little routines that make sounds based on the M5Stack Atom Speaker code examples.
                        The code is at,
                        https://github.com/Hagtronics/M5Stack-Core2/tree/main/Sound
                        I 1 Reply Last reply Reply Quote 1
                        • I Offline
                          ioamas @LostInSpace
                          @LostInSpace I am quite new to all this so could you post a simple code of making a beep with your library.
                          thank you
                          Ioannis
