    UiFlow 1.10.2 Core2 white screen indefinitely
    Bug Report
    4.1k
    • H
      HWTaro9
      Whatever program I run always returns a blank white screen until the device is reset. This happens with all the code I’ve attempted to run, but it’s random.
        sgu
        Try to update to 1.10.4.1
        does this solve the issue ?
          Have you burned the correct Core2 UiFlow firmware ?
          sometimes this happens if you use Core or Core fire firmware instead of Core2 firmware.
          Also, are you including any graphical elements? If you run a program without GUI elements set then the screen will go blank!
