    Stamp C nonblocking led script?
    4 Posts 4 Posters 5.8k Views
      Knobsi
      Hello together,
      using my Stamp C but cannot get the button led running without blocking.
      anybody can point me to a sample for this?
      would be great !
      Thx & cheers, K.
      • felmueF Online
        Hello @Knobsi
        here is a simple non-blocking blinking example for the M5StampC3.
          macsbug
          Hello @Knobsi
          The RGB LED can use the neopixel Write instruction with Arduino ESP32 Version 2.0.4.
          Arduino IDE Boards Manager
          https://github.com/espressif/arduino-esp32/releases?fbclid=IwAR19R5_0Y1bW5DiYk4PBp7RAeFKjNrSo9YJZuHXmwNKY-dT7z_fYDKHzSoI
          Improvements
          • Implemented a simple RGB driver via digitalWrite
          • Implement simple RGB driver via digitalWrite; solving #6783 by @PilnyTomas in #6808
          https://github.com/espressif/arduino-esp32/blob/master/cores/esp32/esp32-hal-rgb-led.h
          void neopixelWrite(uint8_t pin, uint8_t red_val, uint8_t green_val, uint8_t blue_val);
          #define LED_PIN 2
          neopixelWrite(LED_PIN,10,100,200); // GPIO,R,G,B
            AgreeDK
            You can make a new class , create a task to control blink or not, and color, with only one function call in you main code . I have done it, but is on vacation now, so cant share it.
