    UIFlow 1.9.0
    Official Updates
    7
    14
    21.2k
    • F
      Felix22
      Hello
      I have see, there is a new Version 1.9.1. What are the news ?
      Question for 1.9.0: What is
      • Unit Encoder and
      • Smart Config ?
      Thanks for your excellent work.
        Hello @m5stack
        the default GPIOs for the GPS module are incorrect when using M5Core2. They should be GPIO14 and GPIO13 (instead of GPIO17 and GPIO 16).
          @IAMLIUBO im getting memory allocation errors when using 1.9.1 with azure. It looks to be that azure is filling the memory requiring the Core2 to be reset in order to update UIFlow program.
          • IAMLIUBOI
            IAMLIUBO @felmue
            Now the button move to the bottom right,one is call "Run" means the workspace's code only run once,if you reboot the device code won't run again,and another one call "Download" means downlaod the workspace's code to the device filesystem and run, the code in the deivce won't disappear when you reboot or somethings.
            In a word, "Run" button is recommend for developing mode, and "Download" button is deploy after develop.
            • IAMLIUBOI
              IAMLIUBO @Arno
              @arno
              UIFlow 2.0 will support this, sorry for wait us upgrade the UIFlow firmware until that.
              • IAMLIUBOI
                IAMLIUBO
                @jeczmienny
                Sorry for that, the offline version haven't update for a while, there are some reasons why we temporarily stop updating, we will fix it as soon as possible. Sorry again.
                • IAMLIUBOI
                  IAMLIUBO @Felix22
                  @felix22
                  Hi, more info you can get in the below links:
                  Unit encoder
                  smarconfig
                  • IAMLIUBOI
                    IAMLIUBO @felmue
                    Thanks, we will fix this mistake.
                      felmue @IAMLIUBO
                      @iamliubo said in UIFlow 1.9.0:
                      Hello @IAMLIUBO
                      understood, but that was not my point. I am only talking about the "Download" button which when pressed shows a popup saying "Uploading".
                      but it's really just a cosmetic issue - don't worry about it.
                      • IAMLIUBOI
                        IAMLIUBO @ajb2k3
