    PROJECTS
    25
    89
    397.5k
    • frittnaF
      frittna @yashax
      @yashax said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
      Thank you. What is the location of the M5Burner source?
      you find the link is in the first post
      download project: https://github.com/frittna/Crypto_Coin_Ticker
      • F
        frankchau93 @frittna
        @frittna
        Hi there,
        I have a Core 2 and I want to install this. I tried doing this on windows with the installer, however the SD card library isn't compatible with the Core 2, according to this post: https://github.com/frittna/Crypto_Coin_Ticker/issues/3
        Can you compile a version with a SD card library that works? This looks so cool and i really want to try this out!
        • frittnaF
          frittna @frankchau93
          @frankchau93
          i started from zero too so maybe give it a try and search/test if there are other compatible libraries. Since i have no core2 device and beside the (stupid) fact that i cannot use the latest boardmanager (higher than 1.0.4) on a core1 I am kind of stuck. But i guess not forever.. atm i am not really plessed with free time but we would need to know what is causing the problems with boardmanager 1.0.5 and higher first. I suspect the WIFI, the SDCard or the Websockets library. Then only minor changings in code are needed to support core2 i guess.
          • Y
            yashax
            Can someone please help me figure out how to display ticker for TIME crypto coin?
            • Y
              yashax
              Is it possible to have ticker rotate between several crypto coins? Like BTC for 5 seconds, the ETH for 5 seconds, in the loop.
              • frittnaF
                frittna @yashax
                @yashax
                regarding TIME token - I see 4 different tokens with that name but none of it is listed on binance.
                An optional cycling function like you're asking was added in the last version i've released a month ago.
                Scroll up or go to the github source page.
                btw: do you have a core1 unit now?
                • Y
                  yashax @frittna
                  @frittna Yes, picked up 2 Core 1’s with stands. ))
                  Regarding TIME, so if it’s not listed on Binance, it won’t work?
                  Thank you for all your help.
                  J
                  • frittnaF
                    frittna @yashax
                    @yashax
                    yes, thats correct since prize data comes from the binance api only, spot markets, no derivates
                    • Y
                      yashax
                      How can I change clock from 24hr to 12hr?
                      Thank you
                      • frittnaF
                        frittna @yashax
                        you can check at line 500 in the code and simply change lines where is says "time(now)" to "timeFormat12(now)"
                        this will work and will show time in am/pm mode and not in 24h mode.
                        If you want to have a visualisation for am/pm too you would have to find free space first and draw something small with a the isAM() or isPM() function.
                        • Y
                          yashax @frittna
                          @frittna Thank you so much.
                          What’s the while line on the chart?
                          • frittnaF
                            frittna @yashax
                            @yashax
                            the white line is the relative trading volume from the last 24 shown candles
                            • Y
                              yashax @frittna
                              @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
                              Thank you so very much in advance.
                              • D
                                dssguy1
                                Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
                                • D
                                  dssguy1
                                  Forgot to mention, it also says "No JSON in response".
                                  • B
                                    bucket62
                                    I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
                                    • frittnaF
                                      frittna
                                      maybe it could be geo-blocked because here from the EU for example it still works normally!
                                      please test:
                                      https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
                                      and
                                      https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
                                      If only the .us domain works for you i will update the code soon for an .us version.
                                      If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
                                      const char restApiHost = "api.binance.us";
                                      and
                                      const char wsApiHost = "stream.binance.us";
                                        Hello @frittna
                                        FWIW: here in Switzerland both URLs work for me.
                                        • frittnaF
                                          frittna
                                          i uploaded a version that uses binance.us.
                                          Use the M5Burner in my Zip File on Github
                                          • B
                                            bucket62 @frittna
                                            @frittna
                                            Thank you frittna! I am in the U.S. and will try that out today. I will report back if it works.
