    I2C Scanner working on Cameras Grove Connector.
    Scheduled Pinned Locked Moved Lessons and Guides
    1 Posts 1 Posters 3.7k Views 1 Watching
      I managed to get the i2c scanner to work on the cameras grove connecter but still fighting to find the sensors.
      Add the following to the bottom of Boards.txt in the Arduino>hardware>expressiv>esp32
      m5cam.name=M5 Camera
      m5cam.upload.tool=esptool
      m5cam.upload.maximum_size=1310720
      m5cam.upload.maximum_data_size=294912
      m5cam.upload.wait_for_upload_port=true
      m5cam.serial.disableDTR=true
      m5cam.serial.disableRTS=true
      m5cam.build.mcu=esp32
      m5cam.build.core=esp32
      m5cam.build.variant=m5cam
      m5cam.build.board=M5CAM
      m5cam.build.f_cpu=240000000L
      m5cam.build.flash_mode=dio
      m5cam.build.flash_size=4MB
      m5cam.build.boot=dio
      m5cam.build.partitions=default
      m5cam.menu.FlashFreq.80=80MHz
      m5cam.menu.FlashFreq.80.build.flash_freq=80m
      m5cam.menu.FlashFreq.40=40MHz
      m5cam.menu.FlashFreq.40.build.flash_freq=40m
      m5cam.menu.PartitionScheme.default=Default
      m5cam.menu.PartitionScheme.default.build.partitions=default
      m5cam.menu.PartitionScheme.no_ota=No OTA (Large APP)
      m5cam.menu.PartitionScheme.no_ota.build.partitions=no_ota
      m5cam.menu.PartitionScheme.no_ota.upload.maximum_size=2097152
      m5cam.menu.PartitionScheme.min_spiffs=Minimal SPIFFS (Large APPS with OTA)
      m5cam.menu.PartitionScheme.min_spiffs.build.partitions=min_spiffs
      m5cam.menu.PartitionScheme.min_spiffs.upload.maximum_size=1966080
      m5cam.menu.UploadSpeed.921600=921600
      m5cam.menu.UploadSpeed.921600.upload.speed=921600
      m5cam.menu.UploadSpeed.115200=115200
      m5cam.menu.UploadSpeed.115200.upload.speed=115200
      m5cam.menu.UploadSpeed.256000.windows=256000
      m5cam.menu.UploadSpeed.256000.upload.speed=256000
      m5cam.menu.UploadSpeed.230400.windows.upload.speed=256000
      m5cam.menu.UploadSpeed.230400=230400
      m5cam.menu.UploadSpeed.230400.upload.speed=230400
      m5cam.menu.UploadSpeed.460800.linux=460800
      m5cam.menu.UploadSpeed.460800.macosx=460800
      m5cam.menu.UploadSpeed.460800.upload.speed=460800
      m5cam.menu.UploadSpeed.512000.windows=512000
      m5cam.menu.UploadSpeed.512000.upload.speed=512000
      Clone the folder varients>esp32 and rename to M5Cam
      and change
      static const uint8_t SDA = 21;
      static const uint8_t SCL = 22;
      to
      static const uint8_t SDA = 12;
      static const uint8_t SCL = 13;
      recompile and upload and it should now detect any i2c devices connected to the grove connector.
