    Simple fix when upload fails.
    Cores
    16
    49
    351.6k
      Stanszal
      I updated the Arduino IDE to 1.8.5 Installed the usb drivers, it still doesn'y work. When the M5 is plugged in it shows up in the device manager and the port is working correctly. so I know the usb port is good. I also tried lowering the transfer sped as suggested and that doesn't help. I will try to find a capacitor some where. It is kind of disappointing that with all the work that went into this it has problems connecting.
      • JJJ
        JJ
          Stanszal
          I tried the cap, here is a screen shot of whats the problem. The pc is seeing the port, it recognises the driver and is working.
          It is trying to upload, but times out I tried both baud rates neither works.![alt text](0_1515100345875_screen.jpg image url)
          • JJJ
            JJ @Stanszal
              Stanszal
              I tried reversing the cap, It still won't connect. It still has the same timeout problem. Changing baud rate doesn't help either.
              • JJJ
                JJ
                  Stanszal
                  I am using win7 and arduino ide 1.8.5. The board automatically selects the com port when plugged in . The port varies .
                  I have the cap soldered onto dupont leads and have them plugged all the way in. I tried both polarity's
                  I keep getting the "timed out waiting for packet header " error. for whatever reason it won't connect. I have no problems with the ports with various Arduino boards, ESP8266's and ESP32's
                  • JJJ
                    JJ
                    • E
                      ElectroMagus
                      @stanszal 在 Simple fix when upload fails. 中说:
                      As a note, I am having the exact same problem. I'm using PlatformIO, but the esptool output is the same indicating the same underlying error.
                      When I look at the Serial Monitor, it's booted and here is the output:
                      rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                      configsip: 0, SPIWP:0xee
                      mode:DIO, clock div:2
                      load:0x3fff0018,len:4
                      load:0x3fff001c,len:812
                      load:0x40078000,len:0
                      load:0x40078000,len:11404
                      entry 0x40078aa0
                      user code done
                      I recovered mine using the EspressIF ESP32 Download Tool following the M5 guide for loading their MicroPython / Cloud IDE firmware.
                      I wanted to play around with their cloud IDE anyway, but you should be able to use the factory firmware (also on GitHub) or one of the ones in your Arduino compile cache that you know works.
                      Edit: Forgot to mention, I did have to use a 10uf cap across the GND and RST pins as described earlier in the thread in order to get the EspressIf tool to be able to connect.
                        Stanszal
                        After much fiddling around I managed to connect to it. However it is unreliable. This thing is a big disapointment. It is obvious a lot of work went into this thing, but they should have put in a little more to get it to work right out of the box.
                        You can get Various Arduinos, ESP8266's and ESP32's for much less and they just work.
                        • m5stackM
                          so sorry, pls try this.
                            Stanszal
                            try what? add a cap? what type and volts? where can I get 1 cap? how about I send this back and you fix it so it works?
                            • JJJ
                              JJ
                                Stanszal
                                Here is how I see it, I already spent over $40.00 for this thing. Yes, I can spend another $3.50 and order some caps, wait 5 to 6 weeks for them to arrive and they may or may not solve the problem. If this is a known issue you should have included a cap with the device.
                                I tried 3 caps, 2 electrolitica and a polyester one. the result is the same, you need to try to upload the sketch multiple times to maybe get it to work once.
                                  Stanszal
                                  JimiT and ElectroMagnus, thank you for your help
                                  • JJJ
                                    JJ
                                      skelstar
                                      Hey @Stanszal ... I just got one of these and had issues with getting the uploading working. I found that if I reset the device and got the timing right then it would work. You just reset it while the "...____" message is writing. I can't tell you when to do it specifically, you just have to guess.
                                      • K
                                        Kryten
                                        Mine worked great until today. I really don't understand why it stopped working today.
                                          mikemoy
                                          Hi guys, just got mine in today and it kept resetting while trying to program. Started at the forums and found this post.
                                          As a R&D engineer let me first just say the guys at m5Stack know what they are doing on the hardware side. It's an exceptions build, But looking at the schematic, i am kinda shocked they dont have a cap on the reset line.
                                          I tried 3 values and all worked. 0.1uf, 2.2uf & 10uf. Would not go higher than 10uf though.
                                          I stuck a 0.1uf cap on the reset pin to gnd, and mine works just fine now, Typically in this circuit anything =<10uf should work just fine.
                                          In the photo I put a 0805 cap, there. It would be best to stick a 0603 there but I didn't have any.
                                          You can get these locally at mouser or digikey.
                                          0.1uf cap at Mouser
                                          For those of you who dont have solder skills like this you can use a through hole cap like this one externally on the box from "RST" to "G". polarity does not matter for this ceramic cap.
                                          0.1uf Through Hole Cap
                                          ohararpO 1 Reply Last reply Reply Quote 0
                                          • ohararpO
                                            ohararp @mikemoy
                                            I just wanted to say that a 10 uf cap worked great for me!
