    Serial2 Don't compile
    PROJECTS
    21.1k
    • A
      ardisd
      I have recently changed to using https://dl.espressif.com/dl/package_esp32_index.json in the boards manager now any application using serial2 wont comple. I get an error Error compiling for board M5Stack-Core-ESP32.
      David Ardis
        ajb2k3 @ardisd
        @ardisd Can you post a screenshot of the error ouput from arduino?
        • A
          ardisd
          Enclosed screen shot as requested
          I get the same error when compiling Serial2.ino and my own code
            Are you running arduino 1.8.7?
            Thats not all the error.
            • A
              ardisd
              Upgraded to 1.8.7 was on 1.8.5
              This is the error now
                I first thought is to tell you to Backup and delete the SD folders in dropbox and
                C:\programfiles(x86)\Arduino\Librarys\SD
                and then try again.
                Can I see your source code?
                • A
                  ardisd
                  Just the standard serial2 sketch
                  #include <M5Stack.h>
                  HardwareSerial Serial2(2);
                  Serial.begin(115200);
                  // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
                  Serial2.begin(115200, SERIAL_8N1, 16, 17);
                  if(Serial.available()) {
                  int ch = Serial.read();
                  Serial2.write(ch);
                  if(Serial2.available()) {
                  int ch = Serial2.read();
                  Serial.write(ch);
                  • N
                    nnn
                    I got the same problem.
                    I changed the rename of Serial2 and fixed it.
                    →HardwareSerial Serial2_(2);
                    • A
                      ardisd
                      @nnn 在 Serial2 Don't compile 中说:
                      That worked for me
                      David Ardis
