    M5stack programming without Arduino IDE : how ?
    FAQS
    9
    23
    121.1k
    • JJJ
      JJ @jrs
      @jrs Glad you seem to have it working.
      Since yours is working, it should be safe to assume your setup is correct: with M5Stack-IDF installed in the ESP-IDF directory.
      Thanks for the update....
      • C
        Calin
        The easyest way to start with ESP-IDF is by PlatformIO
        That IDE include ESP-IDF, Arduino, Mbed...
        JJJ 1 Reply Last reply Reply Quote 2
        • JJJ
          JJ @Calin
          @calin Great tip re. PlatformIO - will take it for a spin...
          • wtakuoW
            wtakuo
            Hello.
            I started to use M5Stack a month ago. I tried several simple projects using Arduino IDE. Before moving to ESP-IDF based development, I tried a trivial (hello world) project to test my settings.
            Unfortunately, current https://github.com/m5stack/M5Stack-IDF looks outdated and incomplete. So I use https://github.com/m5stack/M5Stack as an IDF component as well as https://github.com/espressif/arduino-esp32 .
            The project directory looks like the following.
            Makefile
            sdkconfig
            components/
                arduino/            (recursive clone of https://github.com/espressif/arduino-esp32, idf-update branch)
                M5Stack/            (clone of https://github.com/m5stack/M5Stack)
                    component.mk    (should be modified. See below)
            main/
                component.mk
                main.cpp            (copy of components/M5Stack/examples/Basics/Hello/Hello.ino)
            The only tweak I did is the addition of src/utlitity to the end of these path variables in components/M5Stack/component.mk.
            COMPONENT_SRCDIRS := . src src/utility
            COMPONENT_ADD_INCLUDEDIRS := . src src/utility
            Without this modification, make cannot correctly find the source codes and headers under src/utility.
            The above setup looks OK and works for other projects.
            My questions are:
            * Is this a correct setup for ESP-IDF projects? (Is there any better one?)
            * Is there any way to avoid the modification of components/M5Stack/component.mk?
            Thank you for attention.
            • wtakuoW
              wtakuo
              My forked and updated version (implementing the setup in my previous post) of M5Stack-IDF template project is available: https://github.com/wtakuo/M5Stack-IDF
              dasloloD wtakuoW 2 Replies Last reply Reply Quote 1
              • dasloloD
                daslolo @wtakuo
                @wtakuo Thank you!
                • wtakuoW
                  wtakuo @wtakuo
                  I fixed my patch in https://github.com/wtakuo/M5Stack-IDF.
                  The path variables in component.mk should look like the following.
                  COMPONENT_SRCDIRS := src src/utility src/Fonts
                  COMPONENT_ADD_INCLUDEDIRS := src
                  As shown in the above code, I added src/Fonts to COMPONENT_SRCDIRS and removed unnecessary "." (current directory) from both paths. Header files in the subdirectories are specified using relative paths from src. So we don't need to add these subdirectories to COMPONENT_ADD_INCLUDEDIRS.
                  Anyway, I sent pull request regarding this fix. If my PR is accepted, the patch file in https://github.com/wtakuo/M5Stack-IDF will be unnecessary.
                  wtakuoW 1 Reply Last reply Reply Quote 0
                  • wtakuoW
                    wtakuo @wtakuo
                    Now my PR has just been incorporated into the latest commit of M5Stack. So I removed patch.txt.
                    In addition, to tidy up the repository of my fixed M5Stack-IDF, I moved my modifications to components_patch branch. So main branch no longer contains the fix now. If you'd like to try my fixed version of M5Stack-IDF, please do like the following commands.
                    git clone --recursive -b components_patch https://github.com/wtakuo/M5Stack-IDF.git
                    Sorry for inconvenience due to the changes.
                    • JJJ
                      JJ @wtakuo
                      @wtakuo
                      Hi wtakuo,
                      thanks for your work on this…. Nice that M5Stack included your work.
                      Your efforts inspired me to give installation another crack – this time using Linux instead of Windows. MUCH better so far.
                      Just have to determine which serial port is in use… got a long list rather than a defined port when following the ESP-IDF setup guide that outlined how to distinguish the serial port in use. Will follow it up laterz.
                      • H
                        hetlelid
                        For reference:
                        Arduino submodule failed. I downloaded the latest, like this (and working):
                        rm -r components/arduino/
                        git clone https://github.com/espressif/arduino-esp32.git components/arduino-esp32
                        cd components/arduino-esp32 && git submodule update --init --recursive && cd ../..
                        Nice if this could be fixed in the code, wtakuo :)
                        • m5-docsM
                          m5-docs
                          Here is the article about programming with Arduino IDE
                          For Windows:
                          https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_Windows.html
                          For MacOS:
                          https://m5stack.readthedocs.io/en/latest/get-started/m5stack_core_get_started_Arduino_MacOS.html
                          M5Stack documentation URL
                          https://docs.m5stack.com
