M5Stack FIRE, faild to init PSRAM
M5Stack FIRE has a PSRAM, but it cannot read the PSRAM's device ID, and external memory test fail with numerous errors.
Why?This is boot log when I try to boot micropython, PSRAM version.
https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/firmwaresRebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0018,len:4 load:0x3fff001c,len:4636 load:0x40078000,len:0 load:0x40078000,len:13040 entry 0x40078530 E (572) cpu_start: Failed to init external RAM! abort() was called at PC 0x4008197a on core 0 0x4008197a: esp_dport_access_int_pause at /home/gombe/bin/esp-idf/components/esp32/dport_access.c:195 Backtrace: 0x40094437:0x3ffe3c70 0x4009458f:0x3ffe3c90 0x4008197a:0x3ffe3cb0 0x400792f9:0x3ffe3cd0 0x40078591:0x3ffe3d10 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20 0x4008197a: esp_dport_access_int_pause at /home/gombe/bin/esp-idf/components/esp32/dport_access.c:195
https://mobile.twitter.com/M5Stack/status/1027828441653989376
I ordered on Aliexpress 2 days ago, from Wavgat.
Is their stock likely to be faulty? They did not answer when asked and sent it anyway.
If faulty, is the solution to replace the PSRAM?
@gombe 在 M5Stack FIRE, faild to init PSRAM 中说:
Why?I'm using an earlier M5Sstack model with PSRAM and it works without any issue.
If you can build the firmware, you could build with VERBOSE LOG bootloader option to get more information about the PSRAM detection and the initialization failure reason.
I have the same issue. I bought M5Stack FIRE in the Aliexpress Store and I get the same boot message..."Failed to init external RAM"
I sent a message to the M5stack devs through Aliexpress but no reply. :(
No PSRAM for me I guess... :(
@lelehel Hi My Friend, did you order it from our official store ? Please kindly send me an email attached your order# and screen shot of the error. I'll help to ship the replacement asap. My email address: teresa@m5tack.com
@jcsbanks Really sorry about the psram problem. The Wavgat store just one of our distributors. Did they refund or send you replacement ? Maybe you can open a dispute for help. If they cannot do any refund or replace, please contact me via teresa@m5stack.com
mode:DIO, clock div:2
entry 0x40078530
[0;31mE (679) cpu_start: Failed to init external RAM![0m
abort() was called at PC 0x4008197a on core 0Backtrace: 0x40094437:0x3ffe3c70 0x4009458f:0x3ffe3c90 0x4008197a:0x3ffe3cb0 0x400792f9:0x3ffe3cd0 0x40078591:0x3ffe3d10 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
Rebooting...
'''Seems like I got the same problem, is it really that the psram is broken?
@bonnom
Try this firmware -
I'll try that when I get home,
The m5burner from the m5stack download page. also has a check psram option and that showed this, maybe handy for people in the feature that want to check if it is working.
